Can't ping to IP Loopback on another Routing Protocol
izhangghani
Hello team,
I have a problem here: CORE_HQ to the ISP uses static default route 0.0.0.0, while CORE_HQ to the downlink uses OSPF. When I try to ping ip lo 8.8.8.8 from CORE_HQ to ISP, it is reachable, but when I try to ping from downlink, say Multilayer Switch 1/2, it is not reachable. Has anyone experienced something similar? Please help me
M02@rt37
@izhangghani
Does ISP router has got a route towards MultiLayer Giga 1/1/1 ?
Best regards
Ruben Cocheno
@izhangghani
Do a traceroute from the switch sourcing from the relevant interface and see where the traffic is stopping. Reviewing the routing table and try to understand the reason why is stopping, it can be a problem from L1 up to L7. Invest your time on how to become more independent and master your skills. Go for it! Any questions just ping me directly, i'm here to guide you.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
izhangghani
Hi, all this problem is already solved, i have added configure PAT on CORE_HQ to advertise ip on the endpoint to ISP_ROUTER
ok Thanks for your feedback @izhangghani
Best regards
