Can't ping VLAN interface from Aironet
tnayak
Could someone please tell me what's wrong with my switch configuration.  I cannot ping devices from my access point or access its web-browser interface.
IP address for vlan 10 interface on the switch is 10.x.x.2
IP address for BVI1 interface on access point is 10.x.x.5
Native VLAN on both the switch and access point is set to vlan 98
FROM THE ACCESS POINT
I cannot ping the switch 10.x.x.2
I cannot ping a device connected to the access point10.x.x.246
FROM THE SWITCH
I can ping a device connected to the access point 10.x.x.246
I can ping the sub-interface for vlan 10 on the router 10.x.x.1
I cannot ping BVI1 on the access point 10.x.x.5
FROM A WIRELESS DEVICE
I can ping the sub-interface for vlan 10 on the switch 10.x.x.2
SWITCH sh ip int brief
sw-public#sh ip int brief
Interface                      IP-Address      OK?    Method     Status                        Protocol
Vlan1                           unassigned      YES    NVRAM    administratively down  down
Vlan10                         10.x.x.2           YES    NVRAM    up                               up
Vlan98                         unassigned      YES    unset       up                               up
Vlan666                       unassigned      YES    unset       down                          down
GigabitEthernet1/0/1   unassigned      YES    unset        up                              up
GigabitEthernet1/0/52  unassigned      YES unset  up                    up
sw-public#
Should the IP address for BVI1 appear next to GigabitEthernet1/0/1?
ACCESS POINT sh ip int brief
ap#show ip interface br
BVI1                               10.10.10.5      YES       manual       up                    up
Dot11Radio0                  unassigned      YES       NVRAM      up                    up
Dot11Radio0.10             unassigned      YES       unset         up                    up
Dot11Radio0.98             unassigned      YES       unset         up                    up
Dot11Radio1                  unassigned      YES       NVRAM      up                    up
Dot11Radio1.10             unassigned      YES       unset         up                    up
Dot11Radio1.98             unassigned      YES       unset         up                    up
GigabitEthernet0            unassigned      YES        NVRAM     up                    up
GigabitEthernet0.10       unassigned      YES        unset        up                    up
GigabitEthernet0.98        unassigned      YES unset  up                    up
ap#
SWITCH CONFIGURATION
switch#show config
Using 14534 out of 524288 bytes
! Last configuration change at 17:30:48 UTC Sat Feb 16 2019 by ares
! NVRAM config last updated at 17:30:56 UTC Sat Feb 16 2019 by ares
version 15.0
no service pad
service password-encryption
hostname switch
boot-start-marker
boot-end-marker
enable secret 5 #########
username ######### privilege 15 secret 5 #########
no aaa new-model
clock timezone UTC -5 0
clock summer-time UTC recurring
switch 1 provision ws-c3750g-48ps
system mtu routing 1500
ip routing
ip domain-name #######.local
ip dhcp database nvram:dhcp_public.txt
ip dhcp excluded-address 10.x.x.1 10.x.x.10
ip dhcp pool public
 network 10.x.x.0 255.255.255.0
 dns-server 10.x.x.1                   IP ADDRESS OF THE VLAN 10 SUB-INTERFACE ON THE ROUTER (10.x.x.1)
 default-router 10.x.x.2               IP ADDRESS FOR VLAN 10 INTERFACE ON THIS SWITCH  (10.x.x.2)
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1              CONNECTS TO AIRONET
 description aironet1
 switchport trunk native vlan 98
 switchport trunk allowed vlan 10,98,666
 switchport mode trunk
abbreviated
interface GigabitEthernet1/0/52             CONNECTS TO ROUTER
 description rt-core G0/1
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description guest_vlan
 ip address 10.x.x.2 255.255.255.0
 no ip route-cache
interface Vlan98
 description native_vlan
 no ip address
 no ip route-cache
interface Vlan666
 description quarantine_vlan
 no ip address
 no ip route-cache
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.x.x.1       IP ADDRESS OF THE VLAN 10 SUB-INTERFACE ON THE ROUTER (10.x.x.1)
line con 0
 exec-timeout 15 0
 logging synchronous
 login local
 length 0
line vty 0 4
 exec-timeout 15 0
 logging synchronous
 login local
 length 0
 transport input telnet ssh
line vty 5 15
 no login
ntp peer 10.x.x.1
end
switch#
ACCESS POINT CONFIGURATION
ap#show config
Using 3347 out of 32768 bytes
! Last configuration change at 00:51:16 EDT Sat May 29 1993 by ares
version 15.3
no service pad
hostname ap
logging rate-limit console 9
enable secret 5 ###########
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
no ip source-route
no ip cef
ip domain name ###########.local
dot11 pause-time 100
dot11 syslog
dot11 vlan-name native_vlan vlan 98
dot11 vlan-name public_vlan vlan 10
dot11 ssid public_SSID
   vlan 10
   authentication open
   authentication key-management wpa version 2
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 ###########
dot11 arp-cache optional
no ipv6 cef
username ########### privilege 15 secret 5 ###########
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 10 mode ciphers aes-ccm tkip
 ssid #########
 antenna gain 0
 stbc
 station-role root
 no dot11 extension aironet
interface Dot11Radio0.10
 encapsulation dot1Q 10
 no ip route-cache
 bridge-group 10
 bridge-group 10 subscriber-loop-control
 bridge-group 10 spanning-disabled
 bridge-group 10 block-unknown-source
 no bridge-group 10 source-learning
 no bridge-group 10 unicast-flooding
interface Dot11Radio0.98
 encapsulation dot1Q 98 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid public_SSID
 antenna gain 0
 peakdetect
 dfs band 3 block
 stbc
 mbssid
 channel width 80
 channel dfs
 station-role root
interface Dot11Radio1.10
 no ip route-cache
 bridge-group 10
interface Dot11Radio1.98
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0.10
 no ip route-cache
 bridge-group 10
interface GigabitEthernet0.98
 no ip route-cache
 bridge-group 1
interface BVI1
 mac-address #################
 ip address 10.x.x.5 255.255.255.0
 no ip route-cache
ip default-gateway 10.x.x.2
ip forward-protocol nd
ip http server
ip http help-path www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
 exec-timeout 15 0
 logging synchronous
 login local
 length 0
line vty 0 4
 exec-timeout 15 0
 logging synchronous
 login local
 length 0
 transport input all
end
ap#
2 Accepted Solutions
I updated my configs as follows:
ON THE AP
Created BVI10 with the following configuration:
   mac-address a46c.2a76.0990
   ip address 10.1.1.5 255.255.255.0
   no ip route-cache
Updated BVI1
   no mac address
   no ip address
ON THE SWITCH
Updated interface GigabitEthernet1/0/1
   switchport access vlan 10
RESULTS
No change in ping test results
Still can't access the AP browser interface
Much more visibility into the AP from the switch — the MAC address table on the switch shows the MAC addresses for devices connected to the AP, but doesn't show the AP's MAC address.  I was able to see the AP using other commands  - see results below:
sw-public#sh mac address-table
Mac Address Table
Vlan    Mac Address       Type        Ports
  10    #####.###.####    DYNAMIC     Gi1/0/1             MAC ADDRESS OF CLIENT CONNECTED TO AP
sw-public#sh ip arp 10.1.1.5
Protocol  Address     Age (min)     Hardware Addr           Type      Interface
Internet  10.1.1.5      22               <AP MAC Address>     ARPA     Vlan10
sw-public#show cdp neighbor detail
Device ID: ap.#######.local
Entry address(es):
  IP address: 10.1.1.5
Platform: cisco AIR-SAP3702I-A-K9,  Capabilities: Trans-Bridge Source-Route-Bridge IGMP
Interface: GigabitEthernet1/0/1,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 155 sec
Management address(es):
the BVI is typically matched to the native VLAN (VLAN 98 is your native Vlan in your case). Can you change the native Vlan on both ends to be Vlan 10 ?
5 Replies 5
at first glance I would say the problem is that you have a BVI for bridge-group 1, but not for 10.
interface BVI1
ip address 10.x.x.5 255.255.255.0 <--what is the real IP address here ?
no ip route-cache
Is Vlan 10 on the switch in the same address space as interface BVI 1?
Hi, please forgive my ignorance, but addresss space = subnet?  If so, the vlan10 on the AP and switch are both in the same subnet, eg switch vlan interface = 10.10.10.2 and BVI1 = 10.10.10.5.
All the online guides that I found for configuring the Access Point for multiple VLANs said to assign the IP address to BVI1. I will try assigning the IP address to BVI10 and post the results.
Thanks for for your help
PS I’m using the following devices/images:
AIR-CAP3702i with IOS 15.3(3)JG1 (fc1)
WS-C3750G with IOS 15.0(2)SE10a (fc3)
ON THE AP
   no ip route-cache
Updated BVI1
   no mac address
   no ip address
ON THE SWITCH
RESULTS
Mac Address Table
Entry address(es):
Holdtime : 155 sec
Thanks for your help and sorry for the delay in updating this post
