Can't route traffic between two site-to-site VPN Tunnels
EM1
We've got an ASA-5525-X in the office here, and we have a VPC in both AWS and Google Cloud Compute. The office has the IP range 10.1.0.0/16, Amazon is 10.2.0.0/16 and Google is 10.3.0.0/16. We have tunnels from the office to both cloud providers. Both the VPN tunnels work fine from individually, We can send traffic between the office and Amazon, and between the office and Google fine. However if we attempt to send traffic from Google to Amazon, nothing happens; and if we try to send traffic from Amazon to Google, the Amazon VPN stops working and needs 'clear ipsec sa peer x.x.x.x'  to reinitialise. Both Amazon and Google are set to route the entire 10.0.0.0/8 over the VPN tunnel.
This is almost certainly down to me doing something very stupid, as I'm fairly new to using Cisco devices, and their VPN set up is somewhat different to the Junipers I was using before; but if someone can spot what it is I've done wrong I'd be very grateful. I've attached a sanitised copy of the runnng config, if any other information would be useful, let me know and I'll provide it.
11 Replies 11
Francesco Molino
Sorry for my typo if any, I'm replying through my iPhone.
Your Google crypto map is passing traffic over tunnel only betwen 10.3.0.0/16 to 10.1.0.0/16 where Amazon is on subnet 10.2.0.0/16.
You'll need to add your Amazon subnet in your crypto acl for Google.
For Amazon, every traffic is coming back to your asa as you set it up with 0.0.0.0, is that normal? Just a simple question for curiosity
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi, thanks for the help, I thought I'd reset all of those back for uploading the config, I need better vlan names. My config at the time I noticed the problem did have the correct cryptomaps, (The GCP map was changed to prevent the issue whereby pinging between s2s tunnels causes the tunnel to drop, and the amazon one was changed to 0.0.0.0 as a test because it was recommended in an Amazon document somewhere.) I've reverted those changes, and forwarded the 10.0.0.0/8 across the tunnel in both cases.
Now that everything is reverted, the problem continues to exist, relevant updated config bits:
access-list AMZN_Cryptomap_ACL extended permit ip object obj-all-internal object obj-amzn
access-list AMZN_Cryptomap_ACL extended permit ip object obj-amzn object obj-all-internal
access-list GCP_Cryptomap_ACL extended permit ip object obj-all-internal object obj-gcp
access-list GCP_Cryptomap_ACL extended permit ip object obj-gcp object obj-all-internal
Removed line:
nat (Outside_Catalyst,Outside_Catalyst) source dynamic obj-amzn interface
The only thing that's changed now, is that the tunnel drop has switched sides: now if I ping gcp from aws, nothing happens, but if I ping AWS from GCP the Office-GCP tunnel stops sending traffic, and needs a 'clear ipsec' to start working again.
Can you do a test with packet-tracer? Do you know how to use? Otherwise I'll give you the command.
Can you share the confoing of all your routers involved in that design!
Francesco
I was under the impression that the packet tracer didn't work for inbound connections over s2s links as it doesn't handle encryption properly, but if thats not true, here they are:
Google > Office (working):
packet-tracer input Outside_Internet icmp 10.3.0.6 8 0 10.1.1.26 deta$
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
in   10.1.1.0        255.255.255.0   Inside_trust_3
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (any,Outside_Internet) source static All_Internal_10 All_Internal_10 destination static obj-gcp obj-gcp no-proxy-arp route-lookup
NAT divert to egress interface Inside_trust_3
Untranslate 10.1.1.26/0 to 10.1.1.26/0
Phase: 3
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
 match any
policy-map global_policy
 class class-default
  set connection decrement-ttl
service-policy global_policy global
 Forward Flow based lookup yields rule:
 in  id=0x7fff33e2a670, priority=7, domain=conn-set, deny=false
	hits=318754, user_data=0x7fff33e1ef80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
	src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
	dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
	input_ifc=Outside_Internet, output_ifc=any
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff348ea800, priority=6, domain=nat, deny=false
	hits=40573, user_data=0x7fff32f2f140, cs_id=0x0, flags=0x0, protocol=0
	src ip/id=10.3.0.0, mask=255.255.0.0, port=0, tag=0
        dst ip/id=10.1.0.0, mask=255.255.0.0, port=0, tag=0, dscp=0x0
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0x7fff32047fd0, priority=0, domain=nat-per-session, deny=true
	hits=32114825, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
	input_ifc=any, output_ifc=any
Phase: 6
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
 in  id=0x7fff32efa030, priority=0, domain=permit, deny=true
	hits=2354590, user_data=0x9, cs_id=0x0, use_real_addr, flags=0x1000, protocol=0
Result:
input-interface: Outside_Internet
input-status: up
input-line-status: up
output-interface: Inside_trust_3
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Amazon to Office (working):
packet-tracer input Outside_Internet icmp 10.2.103.95 8 0 10.1.1.26 detailed
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (any,Outside_Internet) source static All_Internal_10 All_Internal_10 destination static obj-amzn obj-amzn no-proxy-arp route-lookup
Phase: 3
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
 match any
 class class-default
	hits=319242, user_data=0x7fff33e1ef80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff342f27b0, priority=6, domain=nat, deny=false
	hits=110080, user_data=0x7fff34068290, cs_id=0x0, flags=0x0, protocol=0
	src ip/id=10.2.0.0, mask=255.255.0.0, port=0, tag=0
Phase: 5
Type: NAT
Result: ALLOW
Config:
	hits=32121883, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 6
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
	hits=2356229, user_data=0x9, cs_id=0x0, use_real_addr, flags=0x1000, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Amazon to Google (NOT working)
packet-tracer input Outside_Internet icmp 10.2.103.95 8 0 10.3.0.7 detailed
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
in   10.3.0.0        255.255.0.0     via xxxxx, Outside_Internet
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (Outside_Internet,Outside_Internet) source static obj-gcp obj-gcp destination static obj-amzn obj-amzn no-proxy-arp route-lookup
NAT divert to egress interface Outside_Internet
Untranslate 10.3.0.7/0 to 10.3.0.7/0
Phase: 3
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
 match any
 class class-default
	hits=319402, user_data=0x7fff33e1ef80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 10.2.103.95/0 to 10.2.103.95/0
 in  id=0x7fff32f94a30, priority=6, domain=nat, deny=false
	hits=5, user_data=0x7fff33c4d0b0, cs_id=0x0, flags=0x0, protocol=0
	dst ip/id=10.3.0.0, mask=255.255.0.0, port=0, tag=0, dscp=0x0
	input_ifc=Outside_Internet, output_ifc=Outside_Internet
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
 in  id=0x7fff32f90b70, priority=3, domain=permit, deny=false
	hits=143479, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
Phase: 6
Type: NAT
Result: ALLOW
Config:
	hits=32124156, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff32f01f00, priority=0, domain=inspect-ip-options, deny=true
	hits=79691676, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
 class inspection_default
  inspect icmp
 in  id=0x7fff33e0f2c0, priority=70, domain=inspect-icmp, deny=false
	hits=6867, user_data=0x7fff33a6f770, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
	src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=0
	dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=0, dscp=0x0
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 in  id=0x7fff33e1cd30, priority=70, domain=inspect-icmp-error, deny=false
	hits=6867, user_data=0x7fff33e12290, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 10
Type: VPN
Subtype: ipsec-tunnel-flow
Result: DROP
Config:
 in  id=0x7fff348bad70, priority=70, domain=ipsec-tunnel-flow, deny=false
	hits=205, user_data=0x37f4c94, cs_id=0x7fff32503ff0, reverse, flags=0x0, protocol=0
	dst ip/id=10.0.0.0, mask=255.0.0.0, port=0, tag=0, dscp=0x0
Result:
input-status: up
output-interface: Outside_Internet
output-status: up
Action: drop
Google to Amazon (Not working)
packet-tracer input Outside_Internet icmp 10.3.0.7 8 0 10.2.103.95 detailed
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
in   10.2.0.0        255.255.0.0     via xxxxx, Outside_Internet
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Untranslate 10.2.103.95/0 to 10.2.103.95/0
Phase: 3
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
 match any
 class class-default
	hits=320703, user_data=0x7fff33e1ef80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 10.3.0.7/0 to 10.3.0.7/0
 in  id=0x7fff3439ac50, priority=6, domain=nat, deny=false
	hits=120, user_data=0x7fff34066cd0, cs_id=0x0, flags=0x0, protocol=0
	dst ip/id=10.2.0.0, mask=255.255.0.0, port=0, tag=0, dscp=0x0
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
	hits=143574, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
Phase: 6
Type: NAT
Result: ALLOW
Config:
	hits=32146638, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
	hits=79734189, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
	hits=6868, user_data=0x7fff33a6f770, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
	hits=6868, user_data=0x7fff33e12290, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 10
Type: VPN
Result: DROP
Config:
 in  id=0x7fff33d62070, priority=70, domain=ipsec-tunnel-flow, deny=false
	hits=4231, user_data=0x0, cs_id=0x7fff32503ff0, reverse, flags=0x0, protocol=0
	src ip/id=10.0.0.0, mask=255.0.0.0, port=0, tag=0
Result:
input-status: up
output-status: up
Action: drop
The attached ASA is the only router config. The endpoints on Google and Amazon are setup through their webui and have limited configuration options.
Thanks!
Can you make sure your nat(outside,outside) is at the first position?
Francesco
I moved that rule up to the top, no change in outcome.
This is an issue with crypto acl or acl on your ASA.
Can you attach the config in text format please to have an updated one.
Based on the config I saw at the beginning, you have vpn-filter applied. On amazon you authorized any to amazon subnet and vice versa. However, on google, only internal LAN to google and vice versa. The amazon subnet isn't authorized. Can you modify it?
Francesco
I've attached the latest config here, which contains all the suggested changes, including adding amazon to the google cryptomap.
I don't see your acl on your outside interface to allow that traffic.
Can you add that and test please:
access-list outside extended permit ip object obj-amzn object obj-gcp
access-list outside extended permit ip object obj-gcp object obj-amzn
access-group outside in interface Outside_Internet
Can you also the packet-tracer please?
Francesco
I've added those lines, but nothing has changed, no traffic flows either way, and pinging from google>amazon drops the google tunnel. Output of the packet tracer:
AWS > Google
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
in   10.3.0.0        255.255.0.0     via <external IP Address>, Outside_Internet
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
 in  id=0x7fff339d6f40, priority=13, domain=permit, deny=false
	hits=0, user_data=0x7fff2b576d80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
 match any
 class class-default
	hits=683881, user_data=0x7fff33e1ef80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff33b18630, priority=6, domain=nat, deny=false
	hits=4, user_data=0x7fff347de6b0, cs_id=0x0, flags=0x0, protocol=0
Phase: 6
Type: NAT
Result: ALLOW
Config:
	hits=37701204, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
	hits=86356172, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
	hits=9037, user_data=0x7fff33a6f770, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
        hits=9037, user_data=0x7fff33e12290, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 10
Type: VPN
Result: DROP
Config:
 in  id=0x7fff343407e0, priority=70, domain=ipsec-tunnel-flow, deny=false
	hits=3, user_data=0x0, cs_id=0x7fff33924990, reverse, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Google to AWS:
Prowler# packet-tracer input Outside_Internet icmp 10.3.0.7 8 0 10.2.103.95 detailed
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
in   10.2.0.0        255.255.0.0     via <external IP Address>, Outside_Internet
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
 in  id=0x7fff33d5eb30, priority=13, domain=permit, deny=false
	hits=0, user_data=0x7fff2b576b00, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
 match any
 class class-default
	hits=683904, user_data=0x7fff33e1ef80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff341c0730, priority=6, domain=nat, deny=false
	hits=2, user_data=0x7fff32fb4b60, cs_id=0x0, flags=0x0, protocol=0
Phase: 6
Type: NAT
Result: ALLOW
Config:
	hits=37705600, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
	hits=86361902, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
	hits=9038, user_data=0x7fff33a6f770, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
        hits=9038, user_data=0x7fff33e12290, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 10
Type: VPN
Result: DROP
Config:
 in  id=0x7fff32fbdfc0, priority=70, domain=ipsec-tunnel-flow, deny=false
	hits=203, user_data=0x3b3c1c4, cs_id=0x7fff33924990, reverse, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Can you follow this doc and share outputs.
Can you attach the full config of the 3 asas (remove what's confidential) , I'll try to reproduce your issue.
It looks like it's not taking the L2L.
I'm in est timezone, are you available end of afternoon to do a troubleshooting session?
Francesco
