Cannot create more than 1 mst instance
hfakoor222
I've tried defining 2 mst instances in 3 separate topologies and only the first instance is showing up
under show spanning-tree mst
I only see instance 0 (IST) and instance 1, and I am not able to see instance 2
here is my commands
here's output
I tried this again on 2 switches with 3 links, and 2 mst instances, amking sure revision number and domain name were equal in both mst configurations and yet again MST instance 2 is not showing up
Any advice as to why this may be happening?
Martin L
hmm.... something is not ok;  Missing vlan instance 2 and looking at Root switch, yet all ports are blocking state.  if u look at show run , mst configs are ok ?   Are links trunks?
Its could be your image; bad image or it does not like (work) in gns3;
Regards, ML
**Please Rate All Helpful Responses **
hfakoor222
The problem seems to be persisting over different projects I'm working on, at this point I may come back at a later time to work on it
It works now, revision numbers and domain names were not matching up, or vlans were off on given instances
