Cannot ping between 2 NIM-ES2-8 modules in the same ISR 4221
I have a new ISR 4221 with 2 NIM-ES2-8 modules in it and the software version is Cisco IOS XE Software, Version 16.09.02.
I can not ping between 2 hosts connected on each of the modules. When I place the same 2 hosts on one either one of the modules I can ping fine between the hosts. does anyone know what the issue could be?
I would appreciate your support in this.
luis_cordova
Hi jaime@infotrans.cw,
Check what  this link says:
The 4- and 8-port Gigabit Ethernet LAN Switch NIMs provide line-rate Layer 2 switching across onboard Gigabit Ethernet ports. The 4-port NIM has four 10/100/1000 switched Gigabit Ethernet ports. The 8-port NIM has eight 10/100/1000 switched Gigabit Ethernet ports, with a PoE/PoE+ version capable of powering all eight ports. The NIMs furthermore enable direct module-to-module communication through the use of the multigigabit fabric (MGF).
Multigigabit Fabric
The LAN switch NIMs have a gigabit connection to the MGF and transparently integrate into the system. Connecting over the MGF enables the NIM to directly communicate with other MGF-enabled modules in the system without involving the router’s forwarding architecture (Figure 2). Throughput for direct module-to-module traffic using the MGF will thereby not be limited by the platform’s performance license levels. Layer 2 switching of packets is thus done at the full Gigabit Ethernet line rate, either local to each LAN switch NIM or when transferring the MGF with multiple MGF-enabled modules installed in the system; module-to-module MGF traffic throughput is limited to 1 Gbps.
Figure 2.      Direct Module-to-Module Connection Without Involving CPU
C78-612808-07_Figure02
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet_c78-612808.html
I hope this information will be useful to you
Hi Luis, thank you for your email. It certainly points me in the right direction. I have a question though. Do we need to download a module firmware to enable the MGF feature?
Krs,
Scott Plank
Did you find a solution for this? We are having the same issue on a 4321 with two NIM-ES2-8 modules on 16.9.2.
