Cannot ping between trunk port
Arie
In packet tracer that works... After configuration switch 2950 cannot ping any sub-interface ip on router 1841and vice versa - router cannot ping management ip of switch in vlan 99 (10.0.0.253).
It's also funny that from switch on port 24 there is cabel which is connected to ISP router (192.168.0.1) and router is able to ping it...
Can anyone explain me what's wrong and how to fix that?
Below all necessary configuration and picture of network (enclosed)
2950 switch config:
2950#show running-config
Building configuration...
Current configuration : 1330 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 2950
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
switchport trunk native vlan 99
switchport mode trunk
interface FastEthernet0/24
switchport access vlan 192
switchport mode access
interface FastEthernet0/25
interface FastEthernet0/26
interface Vlan1
no ip address
no ip route-cache
interface Vlan99
ip address 10.0.0.253 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.254
ip http server
line con 0
line vty 5 15
end
2950#
1841 router config:
Robert>en
Robert#show runn
Robert#show running-config
Current configuration : 929 bytes
version 12.4
hostname Robert
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.11
encapsulation dot1Q 11
ip address 192.168.2.254 255.255.255.0
no snmp trap link-status
interface FastEthernet0/0.99
encapsulation dot1Q 99 native
ip address 10.0.0.254 255.255.255.0
interface FastEthernet0/0.192
encapsulation dot1Q 192
ip address 192.168.0.254 255.255.255.0
ip address 192.168.59.254 255.255.255.0
duplex auto
speed auto
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Robert#
5 Replies 5
Hi!
Apply this command in interface fa0/23 from switch:
this is unknow ...
I found information that for 2950: "only encapsulation type available on 2950 is dot1q,so by default it is enabled on the port" so switchport mode trunk" should be enough
Indeed, try the steps from following link: http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/14976-50.html
As this is an old switch, I'd recommend to apply the command switchport trunk vlan allowed all
I applied this command: "switchport trunk vlan allowed all"
but still no working.
i checked also:
2950#show int fastEthernet 0/23 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 99 (Inactive)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
2950#
look at his line:
is it something wrong here?
EDIT: ok i had vlan 99 down i bring it up and now its ok
P.S If i restart switch vlans will be automaticly bringed up or do i need to make them up manually?
SVI's come up following a boot, you also need an interface up in the respective vlan.
Martin
