Cannot reach maximum power per port, all ports used,
kevinrandomguy
We are using the C1300-16FP-2g with a PoE+ device.  We have control to a degree of how much power each device can draw.  When we push each port over 13W, closer to 13.5-14W the switch will begin to shed ports (turn them off).  At 204W we are about 85% of the 240W available as reported by the switch.
We've set a lot of different settings on this switch.  Threshold is not on and I don't see any indication that there is some obscure limit per port.  Any idea what is happening and how to address it?
@kevinrandomguy
240W is the maximum supported and this must include the switch itself. This is not accounted only for PoE.
According to Cisco's datasheet the 240W plate advertised is the PoE budget.  I do understand that many switches will lump that in with total power used (device included).  The name plate power for this switch is about 275W.
@kevinrandomguy
 You are right. You should be able to get 15W per port.
C1300-16FP-2G
110V=20.6W
220V=22.1W
110V=281.9W
220V=275.2W
961.3
110V=12.6W
220V=13.6W
