Cannot set ip authentication mode eigrp on 3750 switch running ipservicesk9-mz.122-55.SE8
keithsauer507
Level 7
Level 7
I am trying to configure EIGRP authentication on a Cisco 3750 switch following version:
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE8.bin"
I can create the key chain without an issue, but when I go into an interface Fa1/0/12 for example, it will not accept the command
ip authentication mode eigrp 100 md5
Is it ok to put this on a vlan interface tied to a switchport instead?  This seems to take...
int vlan1
ip authentication key-chain eigrp 100 <keyname>
So if a router is connected to a port in vlan 1 in this example, and they are using the same md5 & key, eigrp should communicate between the two?
This is not production, this is a test for future implementation where a site is just using 3750x2's in layer 3 mode (they don't have an onsite router) and they are going from a simple 1 WAN connection (with a static quad 0 route) to a 2 WAN connection (for backup) and eigrp proposed to handle picking the routes.
acampbell
From the config guide
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/configuration/guide/scg3750/swiprout.html#wp1051432
You can configure the "ip authentication mode eigrp 100 md5" on any layer 3 interface.
So yes you can use interface vlan
or
interface fast 1/0/12 only if this has been set as a layer 3 port ie// "no switchport"
Alex
Regards, Alex. Please rate useful posts.
acampbell
or
Alex
Perfect!!!
I forgot no switchport on that interface.  Yes now I can apply it there, or apply it at the vlan level.
