Cannot telnet between machines behind cisco 1811
IM-Design
I have 2 separate exchange servers for 2 separate exchange organizations on
the same private network.
-One has an ip of 192.168.0.2
-Two has an ip of 192.168.0.3
The network is protected by a 1811 router/firewall and each server has their own
public IP.
I can telnet between these machines usign their private ips, but not using their public ips?
Here is the show run (attached):
Thanks for your help
12 Replies 12
pkhatri
Level 11
Level 11
HI,
That is not possible with the way NAT works. I'm afraid you have no option but to try the telnet from a host on the Internet or just use their private IPs.
Hope that helps - pls rate the post if it does.
Paresh
Do you want to enable smtp exchange between the two Servers using their public IP or you expect telnet between the two servers to work using their public IP?
I believe, there's a way this task be accomplished.
Shall post the config after your response is received.
--Sundar
Hi Sundar,
Do you know of a way to be able to telnet between the machines using their NATed public addresses ? If so, I'd be interested to see how this could be done.
Much appreciated.
Paresh
No problem.
Here it is.
I don't have access to equipment to test at this time. I am just typing it in. Excuse me if there's problems with my syntax as it's 11:40pm over here in US and I am about to call it quit for the day.
int lo0
ip add x.x.x.x y.y.y.y
int vlan1
ip policy route-map test
route-map test permit 10
match ip address 150
set int lo0
route-map test permit 15
match ip address 151
set int lo0
access-list 150 permit tcp host x.y.z.230 host x.y.z.231 eq smtp
access-list 151 permit tcp host x.y.z.231 host x.y.z.230 eq smtp
Let me know if you had any questions.
HTH,
Sundar
I want to enable smtp exchange between the 2 servers. Does the sample you show below apply in this case?
Charlie
Yes.
A small correction to the above:
int lo0
ip address x.x.x.x y.y.y.y
ip nat outside
Let me know if it helped.
--Sundar
Im new to IOS, so I am not following your lead here. Would it be possible for you to modify the originally posted file, so I can follow your advice without making any unintended errors?
Just add/apply the following configuration to your existing setup. Substitute the x/y/z with ip addresses.
int lo0
ip nat outside
int vlan1
set int lo0
set int lo0
Let me know if you have any doubts.
--Sundar
Hi, thanks for the reply
-For the lines:
int lo0
ip nat outside
What ip address & mask should I use (public, or private-192.168.0.253, or something like 127.0.0.1). I would prefer to not use a public.
You could use a private IP address on your loopback.
Let us know how you did with it.
Pls. rate all helfpul posts.
HTH,
Sundar
No joy.
I tried the 127.0.0.1 address, but it was disallowed, as was an address on the 192.168.0.x network. So I chose a 10.1.20.x address, which was successfully set on lo0.
Nonetheless, I am still unable to telnet between the public addresses for these 2 machines.
Any ideas?
TIA
Charlie
Post the config that you have in there now.
--Sundar
