cannot upgrade switches
amysifuma
I am trying to update switches (Catalyst 2960) but it just hangs at the first step (Loading the tar file to the switch). I successfully downloaded the patch and have used it on other switches so I dont think its a corrupted patch issue. See screenshot below:
Please help!
Amy
milan.kulik
Level 10
Level 10
I've several times met different GUI (Java based especially) tools having problems with filenames containing special characters.
I'd recommend to put the file on your PC to a directory with a simple name like C:\IOS.
The space character used in "C:\Switch patches" might be a problem here.
HTH,
Milan
