Err-disabled vlan
Wassim Aouadi
Level 4
Level 4
I have the following config:
interface FastEthernet1/0/37
switchport access vlan 11
switchport mode access
switchport voice vlan 2222
switchport port-security maximum 4
switchport port-security maximum 2 vlan access
switchport port-security maximum 1 vlan voice
switchport port-security violation restrict
switchport port-security mac-address sticky
switchport port-security mac-address sticky 58bc.2775.d83d vlan voice
ip access-group ACL_VLAN11 in
priority-queue out
mls qos trust cos
spanning-tree portfast
spanning-tree bpduguard enable
ip dhcp snooping limit rate 50
The problem is that the computer gets a "limited connectivity", when he launches Microsoft Virtual PC. On this software, there's a virtual computer with a different MAC address. So this counts for 2 MAC addresses (guest and host) on the access vlan.
A "show interface" gave the following:
TNSWACCS01A1#show interface fa1/0/37
FastEthernet1/0/37 is up, line protocol is up (connected) (vlan-err-dis)
  Hardware is Fast Ethernet, address is 0064.4009.6629 (bia 0064.4009.6629)
  Description: *****Aymen hafyenne-******
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:46, output 00:00:46, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 83
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 63000 bits/sec, 45 packets/sec
  5 minute output rate 61000 bits/sec, 44 packets/sec
     798295 packets input, 127873137 bytes, 0 no buffer
     Received 11322 broadcasts (7539 multicasts)
     0 watchdog, 7539 multicast, 0 pause input
TNSWACCS01A1#sh int statu err-disabled
Port      Name               Status       Reason               Err-disabled Vlans
Fa1/0/37  *****               connected    security-violation   11
any idea?
5 Replies 5
p.mcgowan
Level 3
Level 3
looks like there is a security violation.
Have you maxed the number of MACs on the port?
you cna check this with the following command;
"show port-security address"
You might also want to try without the sticky command
Thsi guide explains more on port security
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/20ewa/configuration/guide/port_sec.html
yes I increased it already. I configured 4 MACs: two for voice plus two for access.
Why I chose two for access? because user has Microsoft Virtual PC with one host. So switch port will learn two MAC address on its access vlan.
user port has also dot1x configured. I thought that our switch asked for authentication. And since Machine authentication is configured on ACS, and Virtual PC is not machine-authenticated, it is not authorized:
Jul 14 10:43:54.714 UTC: dot1x-ev(Fa1/0/37): Sending event (2) to Auth Mgr for 0000.0000.0000
Jul 14 10:43:54.714 UTC: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'dot1x' for client (Unknown MAC) on Interface Fa1/0/37 AuditSessionID 0A64FE0B0000012818AA3771
Jul 14 10:43:54.714 UTC: dot1x-ev(Fa1/0/37): Received Authz fail for the client  0x54000938 (0000.0000.0000)
Jul 14 10:43:54.714 UTC: dot1x-ev(Fa1/0/37): Deleting client 0x54000938 (0000.0000.0000)
Jul 14 10:43:54.714 UTC: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (Unknown MAC) on Interface Fa1/0/37 AuditSessionID 0A64FE0B0000012818AA3771
Jul 14 10:43:54.714 UTC: %AUTHMGR-7-NOMOREMETHODS: Exhausted all authentication methods for client (Unknown MAC) on Interface Fa1/0/37 AuditSessionID 0A64FE0B0000012818AA3771
Jul 14 10:43:54.714 UTC: %AUTHMGR-5-FAIL: Authorization failed for client (Unknown MAC) on Interface Fa1/0/37 AuditSessionID 0A64FE0B0000012818AA3771
am I right?
does this work if you remove the "switchport port-security mac-address sticky" command?
Wow.  That's very, very strict.  Can I buy a vowel?
I did a "clear port-sec sticky interface..." and it did not solve the problem.
Leo, security policies in my company are tight
