Capture not allowed on a SPAN destination port
pslavkovsky
Hi all
I have 2 switches Cat6509E. each with IDSM module
I have on first switch this commands
intrusion-detection module 7 data-port 1 capture
intrusion-detection module 7 data-port 2 capture
intrusion-detection module 7 data-port 1 capture allowed-vlan 4,6,16,17,66
intrusion-detection module 7 data-port 2 capture allowed-vlan 68,70,74,134,145
And when I trying to put the same on second switch I will get this error message
Intrusion-detection-module 7 data-port 2:  Capture not allowed on a SPAN destination port
What does it mean?
Output "sh monitor" is the same on both switches
Session 1
Type                   : Service Module Session
Modules allowed        : 1-9
Modules active         : 1,7
BPDUs allowed          : Yes
Session 2
Type                   : Local Session
Source VLANs           :
    Both               : 4
Destination Ports      : analysis-module 8 data-port 1
Peter
Shashank Singh
From the error message, looks like module 7 data-port 2 is also a SPAN destination port.  Can you check the configuration ?
If module 7 data-port 2 is not a SPAN destination, perform the following steps:
  • unconfigure "intrusion-detection module 7 data-port 2 capture",
  • configure "intrusion-detection module 7 data-port 2 capture allowed-vlan 68,70,74,134,145" FIRST and then
  • configure "intrusion-detection module 7 data-port 2 capture".
Let me know if this helps.
Please rate this answer if you found the content useful
