Cat 2950 Switch port down problem
sbjeong
Level 2
Level 2
Cat2950T-24 ___(link1)_____cat2950
<ios ver.>
cat2950T-24: 12.1(13)EA1
cat2950 : 12.1(22)EA8a
1) link1 down
2) I could find logs the following in the cat2950T-24
   SPANTREE-7-RECV-1Q-NON-TRUNK:
   SPANTREE-7-BLOCK-PORT-TYPE:
3) port, stp configurations are factory default
4) any change was none before then
5) That is repeated sometimes
What's the problem?, how can I fix it ?
Plz, help me
Reza Sharifi
Can you post the configs for both switches?
Reza
Sorry, customer's policy don't allow it.
Almost configuration is factory default, and port/stp configuration is factory default.
Are both sides configured as an access ports or trunk port?
I didn't configure the ports "switch mode access" on both switches, so they operate in trunking (802.1q)
Cat2950  only support 802.1q
