Cat 3650 Password recovery process not working
pmikel
I have a Cat 3650 that was shipped to me that was on TACACS (probably) and is asking for username/pw.  I booted the switch to RMON and followed the password recovery steps, and verified the set commands (see below). It still asks for username & pw after boot flash:packages.conf is issued.
I don't care about the old config info....just need to wipe the switch.
Ideas?
Pete
switch: set
BOOT=flash:packages.conf
BSI=0
CFG_MODEL_NUM=WS-C3650-48FS-S
CLEI_CODE_NUMBER=IPMV610BRB
CSR_PCIERST_DISCONNECTED=yes
ECI_CODE_NUMBER=467899
LINUX_COREMASK=15
MAC_ADDR=54:A2:74:33:E3:80
MANUAL_BOOT=no
MODEL_NUM=WS-C3650-48PS
MODEL_REVISION_NUM=H0
MOTHERBOARD_ASSEMBLY_NUM=73-15901-04
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FDO19161TXL
POE1_ASSEMBLY_NUM=73-16439-01
POE1_REVISION_NUM=A0
POE1_SERIAL_NUM=FDO19161UQ1
POE2_ASSEMBLY_NUM=73-16439-01
POE2_REVISION_NUM=A0
POE2_SERIAL_NUM=FDO19161UNZ
RANDOM_NUM=1498441355
RECOVERY_BUNDLE=sda9:cat3k_caa-recovery.bin
RET_2_RTS=15:47:41 EDT Thu Jun 25 2015
SWITCH_NUMBER=1
SWITCH_PRIORITY=15
SYSTEM_SERIAL_NUM=FDO1916E3G0
TAN_NUM=800-41231-01
TAN_REVISION_NUMBER=A0
TEMPLATE=advanced
TERMLINES=0
VERSION_ID=V02
manual_boot=n
switch_ignore_startup_config=1
0 Replies 0
