3750x Intervlan Routing Not Working
Ed Willson
I have a 3750x Stack where intervlan routing appears to be partally broken. IP Routing is enabled.
Version:
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E1, RELEASE SOFTWARE (fc2)
The Two VLANs:
FWC-Hen-Swi-Core#  show run int vlan 1
Building configuration...
Current configuration : 58 bytes
interface Vlan1
 ip address 10.10.40.0 255.255.0.0
end
FWC-Hen-Swi-Core#  show run int vlan 15
Current configuration : 59 bytes
interface Vlan15
 ip address 10.15.40.1 255.255.0.0
end
Ping results VLAN 1:
FWC-Hen-Swi-Core#ping 10.10.80.20 source vlan 1
Sending 5, 100-byte ICMP Echos to 10.10.80.20, timeout is 2 seconds:
Packet sent with a source address of 10.10.40.0
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/17 ms
FWC-Hen-Swi-Core#ping 10.10.80.20 source vlan 15
Packet sent with a source address of 10.15.40.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/12/34 ms
FWC-Hen-Swi-Core#
Ping results VLAN 15:
FWC-Hen-Swi-Core#ping 10.15.80.118 source vlan 15
Sending 5, 100-byte ICMP Echos to 10.15.80.118, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/9/33 ms
Success rate is 0 percent (0/5)
FWC-Hen-Swi-Core#
Routing table:
Gateway of last resort is 10.10.30.2 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.10.30.2
      10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C        10.10.0.0/16 is directly connected, Vlan1
L        10.10.40.0/32 is directly connected, Vlan1
C        10.15.0.0/16 is directly connected, Vlan15
L        10.15.40.1/32 is directly connected, Vlan15
FWC-Hen-Swi-Core#
Hello.
Please run traceroute from 10.15.80.118 to 10.10.40.0
Also disable ip-redirects on both SVIs (then wait for an hour or reload affected host).
