cat 6500 issue
rajbhatt
Level 3
Level 3
Hi all,
while trying to upgrade  a cat 6500 image ,a wrong image was inserted  and set to sup boot
Now it is going to loop and rom mon mode and the switch is not booting .
How do I recover the  the  switch to boot properly.
when I do a dir sup I see the image and set the wrong image .
When I do a
rom1>boot boot flash:cs72033-pk9s-mz.122-17d.SXB6.bin   ,
it says reset and when I do that it tries to boot froma  wrong image . c6msfc2-adventerprisek9_wan-mz.122-18.SXf17
I dont have a image saved in disk 0  and disk 1 .
attching the cecreen shots .
Any help would be highly appreciated .
thanks
There is a option to upgrade the IOS from rommon mode. Upgrade the correct IOS via rommon mode and boot the switch via this new IOS.
I too faced the same issue and we have upgraded the IOS via rommon, and got success.
To upgrade the IOS in rommon mode just go through this below URL
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
regards
karuppu
This is what I did , but as I mentioned I do not have a saved image in disk 0 or disk 1. it was done by a newbie and ZI have to fix it
when I do set the boot path it gives me an option to reset -s and then loads from the old image
thanks for ur reply
hi,
Thanks .
just fixed it with boot: supbootflash:
It took the default image
Thats great.. Enjoy..
regards
karuppu
