04-20-2009 06:59 PM - edited 03-06-2019 05:17 AM
I have problem with one of my Cat 6500 module that cannot work.
The module is WS-X6548-GE-TX and currently using "c6sup22-psv-mz.121-13.E9.bin".
I check cisco website and it's recommended use "12.2(17d)SXB" IOS version. But when I check, this version has been deferred.
Does anyone help me, what IOS version that can make my WS-X6548-GE-TX work properly ?
Additional information :
I'm using Supervisor Engine 2 (WS-X6K-SUP2-2GE)
thanks
04-20-2009 08:02 PM
Could you post output of a "sh module"
04-20-2009 10:57 PM
Here is the output :
CORE#sh module
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SALXXXXXXXX
2 2 Catalyst 6000 supervisor 2 (Standby) WS-X6K-SUP2-2GE SALXXXXXXXX
3 24 SFM-capable 24-port 100FX Multi mode WS-X6524-100FX-MM SALXXXXXXXX
4 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45 SALXXXXXXXX
5 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SALXXXXXXXX
6 48 unknown FRU type (major = 0x6003, mino WS-X6548-GE-TX SALXXXXXXXX
Mod MAC addresses Hw Fw Sw Status
1 0006.d65d.41xx to 0006.d65d.41xx 4.3 6.1(3) 7.5(0.6)HUB1 Ok
2 0006.d65d.44xx to 0006.d65d.44xx 4.3 6.1(3) 7.5(0.6)HUB1 Ok
3 000d.659b.dexx to 000d.659b.dexx 1.6 6.3(1) 7.5(0.6)HUB1 Ok
4 000d.bd0d.d6xx to 000d.bd0d.d6xx 1.3 5.4(2) 7.5(0.6)HUB1 Ok
5 0013.7f0e.0fxx to 0013.7f0e.0fxx 3.1 5.4(2) 7.5(0.6)HUB1 Ok
6 001d.a25f.3exx to 001d.a25f.3fxx 11.3 Unknown Unknown PwrDown
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 SALXXXXXXXX 3.4 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SALXXXXXXXX 2.5 Ok
2 Policy Feature Card 2 WS-F6K-PFC2 SALXXXXXXXX 3.4 Ok
2 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SALXXXXXXXX 2.5 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
6 Unknown
04-21-2009 01:32 AM
Arianto
If you are running in native mode then you need a minimum of 12.1(19), see this link -
If you are in hybrid mode then you need CatOS minimum of 7.6(1) on the supervisor engine.
If you are in native there is nothing to stop you upgrading to a 12.2SXF version which will support your card although you need to check the memory requirements, see this link -
Jon
04-21-2009 05:52 PM
Hi Jon,
thanks for your help.
i will try for this.
