Cat 9300 firmware not upgrading
kalen4101
Switch(config)# boot system flash:packages.conf
Switch(config)# exit
write memory
switch#install add file flash:cat9k_iosxe.16.09.04.SPA.bin activate commit
switch is currently using "cat9k_iosxe.16.09.02.SPA.bin"
 I've use the above on 2 other cat 9300 switches all using cat9k_iosxe.16.09.02.SPA.bin and both upgraded flawlessyly and are running cat9k_iosxe.16.09.04.SPA.bin right now.
 But the third switch I ran it once, reloaded and all the messages indicated it was successful. But "show ver" still shows it on the old firmware.
 So I ran it again, watching each step for a failure or error message, there is nothing. Every result says "successful". Am I missing something?
kalen4101
 So the solution was really quite simple. The first 2 switches I did
write memory
and everything went great. But every switch after that failed. Well for some reason it worked in the first 2 switches but every switch after that it didn't and you got
show boot
BOOT variable = flash:cat9k_iosxe.16.09.02.SPA.bin;flash:packages.conf;
 Once I did
Switch(config)#no boot system
write memory
it worked perfectly fine
5 Replies 5
Reza Sharifi
The file may have been corrupted during the transfer. So, try copying the IOS on to the flash again and than go through the same procedure.
nlawrance
1)First give # dir fash:
Check bin file is there in flash
2)if not give command
copy tftp://192.168.3.47/file name flash:
 it copy image from tftp server to flash
3)Then package installation
#request platform software package install file flash:<filename>
or
#request platform software package install switch all file flash:<filename> (check which one works)
then
#reload
4)Then to clean software
#request platform software package clean
if it say used package may deleted the don't delete it else delete it.
OK, fails for
switch#request platform software package install switch all file flash:cat9k_iosxe.16.09.04.SPA.bin
--- Starting install local lock acquisition on switch 1 ---
Finished install local lock acquisition on switch 1
FAILED: switch local is not booted with provisioning file
switch#
Leo Laohoo
Post the complete output to the following commands:
sh boot
more flash:packages.conf | b CAT9
kalen4101
write memory
show boot
 Once I did
write memory
