Cat 9300 series switches
peterdervan
Historically, there used to be an allocation of ports on a switch assigned to an ASIC within the switch. Various commands, eg. show int gig1/0/1 cap, for example, might indicate which group of ports were assigned / using the same ASIC.
I was reading the current 9300 series architecture white paper, and I see mention of UADP asic, and 6 rings internally etc, but I'm not sure if there is still an allocation of ports per a dedicated asic, or not (maybe just one common asic these days?).
Could anyone advise on current (eg. 9300) switches in regards to this topic? I am trying to analyse port & BW requirements from an Infra team, to decide if there is any switch limitations that I should be wary of (ie. cable up high BW devices to different ASICs for example).
Any help would be great. Thanks
Reza Sharifi
Your understanding is correct. Depending on the switch model, they use 1x UADP chipset (ASIC 0) or 2x UADP (ASIC 0 and 1). See Figures 1-11
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-architecture-cte-en.html
Joseph W. Doherty
From what I recall (?) reading 9k architecture papers, every port has equal access to resources so that there's no advantage to try to distribute port loading.
However, unknown what happens if a particular ASIC fails.  I.e. a group of ports fail with it, or whether there's potential service degradation to all other ports.
