Cat 9300 showing error after upgradations- .Package is missing
Mayur Salunkhe
Recently i have competed IOS upgradation of cat 9300 switch after upgradation i got error like package is missing.
when i checked more package.conf file all files are present in file nothing is missing still getting error.
Also when i checked sh boot sys under boot sequence old file .bin also there and new package.conf also there.
13 Replies 13
Leo Laohoo
Post the complete output to the following commands:
dir
more bootflash:packages.conf | begin rp_boot
Please find attached output
Where?
Attached,
Leo Laohoo
F.ck. I think DNAC erased everything.
This can be fixed easily.
1.  Copy the firmware back into the switch.
2.  Do the following:
conf t
 software auto-upgrade enable
end
wr
3.  Unpack the package:
request platform software package install switch all file flash:filename.bin on-reboot new auto-copy verbose
4.  Confirm that the switch will boot the correct firmware:
5.  Save the config.
6.  Reboot
is there any another way without reboot when i checked files under package.conf all files are there shall i uploade .bin file and extract it into packages bcz under dir latest version bin file is delated.
Follow Steps 1 to Step 4 and it will put the package files back without a reboot.
This is a stack of 9300 -- Lady Luck shines down on you.  Look at Step 3.  Do you see the option "on-reboot"?  (That's a bug:  CSCve94966.  It is suppose to say "NO-reboot".)   If the option "on-reboot" is used, the process will extract all the packages from the BIN file and STOP.  No reboot.
Please share with us the DNAC version or build number for references.
Hi Leo,
We are not using DNAC to upgrade device we have inhouse automation tool.
Hi Leo,
Thanks for help, i restored files in switch but still showing error under sh logg.
Please find attached snap
conf t
 service internal
end
clear install state
conf t
 no service internal
end
wr
@Mayur Salunkhe
What is the DNAC version?
(This information is very important because some DNAC people are watching this thread.)
Hi Leo,
We are not using DNAC to upgrade device its inhouse automation tool.
