Cat OS to Cisco IOS conversion in 6509
this is the current
Mod Port Model               Serial #    Versions
1   2    WS-X6K-SUP2-2GE     SAL0652AHVM Hw : 4.1
                                         Fw : 7.1(1)
                                         Fw1: 6.1(3)
                                         Sw : 7.4(2)
                                         Sw1: 7.4(2)
15  1    WS-F6K-MSFC2        SAL0652AXCK Hw : 2.5
                                         Fw : 12.1(13)E3
                                         Sw : 12.1(13)E3
       DRAM                    FLASH                   NVRAM
Module Total   Used    Free    Total   Used    Free    Total Used  Free
1      131072K  59394K  71678K  32768K   7627K  25141K  512K  287K  225K
Uptime is 1472 days, 23 hours, 32 minutes
****************** show flash ******************
bootflash:
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
  1 .. ffffffff def8601e  6729b4   24  6236468 Jan 24 2003 05:25:15 cat6000-sup2k8.7-4-2.bin
25744972 bytes available (6236596 bytes used)
slot0:
  1 .. ffffffff e49755b3   207d4   24     1875 Jul 29 2003 15:06:08 cat6000-sup2k8.7-4-2.bin
  2 .. ffffffff b597155e  1bde44   25  1693168 Jul 29 2003 15:11:31 c6msfc2-boot-mz.121-8a.EX
  3 .. ffffffff 463ae8d7  e35aa0   28 13073372 Jul 29 2003 15:18:41 c6msfc2-psv-mz.121-13.E3.bin
9872736 bytes available (14768800 bytes used)
I am planing to upgard
s222-advipservicesk9_wan-mz.122-18.SXF17a.bin  and c6msfc2-boot-mz.121-27b.E4.bin
this is the requirment for the new IOS
ADVANCED ENTERPRISE SERVICES SSH Service Contract Required
s222-adventerprisek9_wan-mz.122-18.SXF17a.bin
Release Date: 19/MAR/2010
Size: 50854.57 KB (52075076 bytes)
Minimum Memory: DRAM:256MB   Flash:64MB
after upgading the DRAM to 256MB is it possible to upgrade the following IOS will it works successfully ?
sdheer
Hi ,
You can do the upgrade you mentioned in your question.
Please refer to the following document which will guide you with the steps for doing that
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
Swati
