Cat3550 LED steady green
m.belateche
Hi All
whenever the switch is powered on all of the 48 ports LEDs turn steady green and nothing appears on the terminal connected to console port. Then nothing happens and the switch remains in this state.
Any hope to return the switch back to normal?
Reza Sharifi
Have you tried to turn off the switch then hold the mode button located on the left side of the front panel and see if you can break into the switch?
Reza
