Cat4500e Sup7e Flow control - strange log
pic_whizz
We have just deployed a large number (33) Cat4500e SUP7e running 3.3.2 IOS XE. Only on one switch we see this message in the logs:-
%C4K_NOVAFFM-3-SPIMANEXCESSIVEFLOWCONTROLWAIT: STANDBY:SpiMan: excessive wait > 10000 ms blocking for flow control on RkNovaFfmL2_AggPortUpdate count == 85125 (suppressed 3 times)
I cannot find any info on this error. Please could someone explain what this means and what the fix is..
Many Thanks,
Matt
6 Replies 6
Wilson Bonilla
Level 3
Level 3
Hi Matt.
Those messages come in the logs when excessive amount of mcast packets are punted to the CPU. I would say if you don't see high cpu utilization you don't really need to worry about, maybe it was a SEU.
Wilson B.
andyirving
The FFM is the Forwarding Feature Manager in IOS XE, this is essentially the control plane, so it does look like its an internal error rather than a data plane issue.
As it only happens on one of the 33 switches I think it is a transient issue, a reboot is in order I think.
Let us know if it resolves the issue for future reference.
Andy I
Hi Matt,
Do you resolve your problem ?
I get the same type of logs on a 4500X VSS (IOS XE 03.04.00.SG) :
Apr 18 11:30:31: %C4K_NOVAFFM-3-SPIMANEXCESSIVEFLOWCONTROLWAIT: SpiMan: excessive wait > 10000 ms blocking for flow control on RkNovaFfmL3_UnionUpdateBulk count == 14399 (suppressed 6 times)
Apr 18 11:31:05: %C4K_NOVAFFM-3-SPIMANEXCESSIVEFLOWCONTROLWAIT: SpiMan: excessive wait > 10000 ms blocking for flow control on RkNovaFfmServicePolicy_onServicePolicyUpdate count == 5183 (suppressed 6 times)
Lionel
Hi  Lionel,
As Wilson stated above I will stand with him on the same answer:
C4K_NOVAFFM-3-SPIMANEXCESSIVEFLOWCONTROLWAIT<http://www.cisco.com/cgi-bin/Support/Error
decoder/index.cgi?action=search&counter=0&paging=5&links=reference&index=all&query=C4K_NOV
>  SpiMan: excessive wait > 10000 ms blocking for flow control on RkNovaFfmMfib_UnionBulkUpdate count == 688 (suppressed 3 times) Action plan: The reason for those messages was that there were many packets in CPU queue waiting to be processed. Workaround: Just reload the switch and let me know the status of the switch.
Inayath
*Plz rate all usefull posts.
Hi Inayath,
A reload of the entire VSS and I no longer receives the logs.
Before reloading i tried a VSS switchover : it had no effect on the logs.
thanks for your help,
Lionel
Hi Lionel,
Thanks for the update. Happy to hear the news.
REgards
Inayath
