Cat4948 output queuing stats
chris.rhodes
I'm configuring qos and transmit queuing on a Cat4948 switch, as per below. I cannot find any commands that allow me to view the transmit queue usage. The only commands I can find just show me the config.
interface g1/1
qos trust cos
tx-queue 1
bandwidth 128000 bps
shape 1024000 bps
tx-queue 2
bandwidth 358400 bps
shape 1024000 bps
tx-queue 3
priority high
shape 512000 bps
tx-queue 4
bandwidth 25600 bps
shape 1024000 bps
QoStest-Cat4948#sho qos int g1/1
QoS is enabled globally
Port QoS is enabled
Administrative Port Trust State: 'cos'
Operational Port Trust State: 'cos'
Trust device: none
Default DSCP: 0 Default CoS: 0
Appliance trust: none
Tx-Queue Bandwidth ShapeRate Priority QueueSize
(bps) (bps) (packets)
1 128000 1024000 N/A 2336
2 358400 1024000 N/A 2336
3 250000000 512000 high 2336
4 25600 1024000 N/A 2336
I'm looking for equivalent commands as Cat6500 "sho queueing int g1/1" or Cat3750 "sho platform port-asic stats enqueue f0/1"
Any suggestions appreciated.
chris.rhodes
The Cat6500 command only reports frame drops by transmit queue not transmitted frames by transmit queue which is what I want.
I've raised an SR on this and will post any outcome
Results of SR:
How to get a report of usage by transmit queue:
C4948 "show interface f0/1 count detail"
C6500 No command available available with current line card revision
