Cat4K IOS - LAN Base vs IP Base vs Enterprise Services
ctychan
Anyone had a table shown the features difference among LAN Base, IP Base and Enterprise Services IOS???  In particular, want to check "IP multicast routing" feature can be turned on with IP Base IOS.  A bit confuse in features nagviator and below picture...
The table should look like
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_presentation_c97-494780.pdf
Jon Marshall
Which supervisor ?
Jon
Sup6-E or Sup6L-E or Cat4900M
The attach chart is not appliable to classic Sup, right?
You are right, Feature Navigator isn't very clear.
From the Sup 6-E datasheet
Licensing
EIGRP, OSPF, BGP and VRF-Lite, NSF, Multicast Routing, IGMP, MLD (Q1 CY'08 Release) are included with Enterprise Services Software image.
full link -
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps9294/product_data_sheet0900aecd806df543.html
Jon
