Cat65 can not auto-reload
pt_wang
My Cat65 can not auto-reboot now. Someone can help me?
rommon 8 > dir bootdisk:
Initializing ATA monitor library...
Directory of bootdisk:
8602    76314468  -rw-     s72033-adventerprisek9-mz.122-33.SXI5.bin
2      33554432  -rw-     sea_console.dat
2050    33554432  -rw-     sea_log.dat
4098    490225    -rw-     debuginfo_20130716-143729-TPE
13260    76335972  -rw-     s72033-adventerprisek9-mz.122-33.SXI6.bin
4128    139899716 -rw-     s72033-ipservicesk9_wan-mz.122-33.SXJ1.bin
rommon 9 > reset
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
I set BOOT=bootdisk:s72033-adventerprisek9-mz.122-33.SXI5.bin
rommon 1 > BOOT=bootdisk:s72033-adventerprisek9-mz.122-33.SXI5.bin
rommon 2 > sync
rommon 3 > sync
rommon 4 > sync
rommon 5 > reset
rommon>
rommon>  comes up  (failed)
I use set command:
rommon 1 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
PF_REDUN_CRASH_COUNT=0
SLOTCACHE=
SWITCH_NUMBER=0
CRASHINFO=bootflash:debuginfo_20130716-143729-TPE
boot=
NT_K=0:0:0:0
BSI=0
RANDOM_NUM=7564149
RET_2_RTS=10:00:16 TPE Thu Jul 18 2013
RET_2_RCALTS=1374112294
?=0
Only I boot this Cat65 is keyin boot command
rommon 2 > boot
string is bootdisk:s72033-adventerprisek9-mz.122-33.SXI5.bin
Loading image, please wait ...
Self extracting the image... [OK]
Self decompressing the image : #################################################
###################################################################### [OK]
InayathUlla Sharieff
Try this:
Dev
Set
Sync
reset
boot bootdisck:imagefile
dir bootdisk
sync reset
REgards
Inayath
I did try this:
dev
set
sync
reset
boot bootdisk:imagefile    <--------- on this command the cat65 sup720 can boot system, it is entering IOS boot
dir boot <---- it is only enter rommon>, I already boot-up sup720
sync reset <---- same as above
rommon>
i keyin reset
the first message is:
then  rommon> come out
It seem to be at SP
while
rommon 1 > boot bootdisk:s72033-adventerprisek9-mz.122-33.SXI5.bin
it seem to be bootup RP
