Cat6509/SUP720 - VSS with Dual SUP Engine
tckoon
2 units of cat6509 switches, both with dual SUP720 engine. After I configured both switches with VSS, both switches standby SUP engine went into RMON. The VSS is working fine.
Why this happened? can't each chassis have one active and one standby SUP ?
Jerry Ye
Hi Choh,
What version of IOS are you running? SXH only support single SUP in each chassis of thre VSS. The newer SXI will support dual SUP in each chassis.
HTH,
jerry
7 Replies 7
Jerry Ye
Hi Choh,
HTH,
jerry
current IOS is 12.2(33)SXH5
well thanks, will upgrade it to SXI
regards
Hi Jerry,
Both switches upgraded to SXI2, the VSS running fine. But when I try bootup the standby SUP on the same chassis ..it will crashed and goto ROMMON. I try another chanssis same problem happned.
will Attached the crashinfo & show tech later, currently having problem to attached here, keep timeout.
Hi Choh,
Just double check, dual SUP support is not here yet but it is coming. I missed read it as service module, sorry for the wrong info.
jerry
Hi Jerry,
Do you know the roadmap ? When it going to release ?
CHOH,
Only single sup is supported for now even with SXI2
Take a look at this wite paper
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/white_paper_c11_429338.pdf
Reza
Hi Choh,
I think it is better for you to check with your local Cisco rep for the roadmap.
jerry
