Catalys 6504-E nat configuration problem
Selenia Irais Nieves Zamudio
Frequent Visitor
Frequent Visitor
Hi Everybody.
I  have a big problem witch my catalyst, it has the IOS version show  below, and I can not finish to configure  NAT because the switch does  not support the command ip nat pool. I find in the cisco page and it  saids that the IOS IP Base support NAT. I hope someone can tell me how  to configure the pool of public address. In my case the ip nat iside  source list x interface gx/x does not apply because I have 4 public  address.
Cisco IOS Software, s3223_rp Software (s3223_rp-IPBASEK9-M), Version 12.2(33)SXJ1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 22-Jun-11 17:11 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Switch-IQUIMICA uptime is 40 minutes
Uptime for this control processor is 40 minutes
Time since Switch-IQUIMICA switched to active is 39 minutes
System returned to ROM by power on (SP by power on)
System restarted at 20:12:10 UTC Mon Oct 3 2011
System image file is "sup-bootdisk:s3223-ipbasek9-mz.122-33.SXJ1.bin"
Last reload reason: Unknown reason
--More--         compliance with U.S. and local country laws. By using this product you
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6504-E (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1524GJUS
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
8 Virtual Ethernet interfaces
57 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102 .
0 Replies 0
