Catalyst 1000 web GUI!
Moudar
I got a Catalyst 1000 switch (C1000-8FP-E-2G-L)
When i try to open the GUI i get this:
When i click on "Web Console - Manage the Switch through the web interface." i get
404 Not Found
 Any ideas?!
  - You don't need /image flag ,  use /overwrite /reload    (the latter however will reboot the switch too) :
                archive download-sw /overwrite /reload  tftp://10.32.0.166/c1000-universalk9-tar.152-7.E4.tar
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
16 Replies 16
Mark Elsen
 - You need to use software distribution  named 'with web based dev mgr' when downloading software from Cisco on it ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
this is the installed image:
When i tried the other available image (c1000-universalk9-mz.152-7.E7.bin) on Cisco software download website, i got this error.
 - The ERROR for the bin file download means  that it is corrupt, anyway you don't need the single bin file ; check if there is an html directory in the C1000.... directory on the flash ; if not download and install the tar distribution again ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I am using this command to upload the image to the switch:
archive download-sw /image tftp://10.32.0.166/c1000-universalk9-tar.152-7.E4.tar
is it the right way to do it?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you, now it is working!
But what is this?
I tried Chrome and Firefox and got same result
                          - But what is this? : ...{{platform}} {{deviceDescription}}
  - That is a bug similar as in : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo35537
 M.
       Beauty and terror
      Just keep going
       No feeling is final
the solution found in the CSCvo35337 does not work.
same problem continues to be there at the top of the page!!
       - It's a cosmetic issue , you may want to escalate to TAC , if desired ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Mark Elsen
  (-Adding) : and  or use .tar extension  named file ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
impulsion84
Frequent Visitor
Frequent Visitor
And there i was thinking that i was the only one with this problem 🙂
impulsion84
Frequent Visitor
Frequent Visitor
This solved the issue for me:
ip http authentication local
Worked for me. Thanks for this quick tip.
rptajpuriya
Community Member
config file is not found in C1000 Switch reset command output
