Catalyst 2560G Vlan and Tags
Hi, I want to communicate from one pc to another over the switch.
At the 1-st pc i have activate 2 vlan tags(at one network card) and set them two diffrent static IPs.
In the switch, i connect the output to the 0/5 interface, that is a trunk entcapuslates dot1q and has access to the vlan 2 of the switch.
Now ping from the 1-st pc to the ip of vlan 2 works.
At my laptop, network card widhout tags, i connect the wire to the 0/13 interface and set the switchport mode to auto and also allow the access to vlan2.
Now i can ping from the 1-st pc the vlan2 and the laptop.
From the laptop, i can ping the vlan2 and one of the static IPs at the 1-st pc, but not the second IP of the first pc.
How can i comunicate with both channels from the laptop? Thx
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Normally you would need to route between the VLANs.
Hello Joseph,
seems to be a answer but i still dont figure it out. Can i do this with the switch with static routing?
Can you give me an example? I have wire the 1-st pc to GigabitEthernet0/5 and the Laptop to  0/9.
Switch#show startup-config
Using 3244 out of 524288 bytes
! Last configuration change at 07:35:55 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5 $1$g4nT$PNFyfAL.PNmQcS5hoe3X51
no aaa new-model
system mtu routing 1500
ip routing
crypto pki trustpoint TP-self-signed-4271110656
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-4271110656
 revocation-check none
 rsakeypair TP-self-signed-4271110656
crypto pki certificate chain TP-self-signed-4271110656
 certificate self-signed 01 nvram:IOS-Self-Sig#6.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan dot1q tag native
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
 switchport access vlan 2
 switchport trunk native vlan 2
 switchport trunk allowed vlan 2
 switchport mode trunk
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 switchport mode access
