Catalyst 2900XL and Xyplex 1600 terminal server - help
slwkk2007
Hi, I bought Xyplex terminal server recently. My problem is that I can't connect to my switches - Catalyst 2900XL - with routers there is no problem. I found this web page:
http://www.gno.org/~gdr/xyplex/cables.html
but unfortunately pinout found there also doesn't work for me.
Does anybody have this working? Thanks in advance for any info.
ccbootcamp
Level 7
Level 7
Can you change the flow control on the Xyplex?
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
I was trying with enabled and disabled flow control on Xyplex, but it didn't change anything.
My 'base' Xyplex configuration I downloaded from:
http://www.gno.org/~gdr/xyplex/init-commands.txt
It's a bit confusing, why all of my routers work and switches don't..
