Catalyst 2940-8TT Configuration
dstochmal
Once I login to my switch through HyperTerminal what is the command to upload txt file with my configuration to the switch? I’m new at this, thx.
Josef Oduwo
Level 7
Level 7
Dariusz,
Welcome.
Open you text file. "Copy" the configuration text which you want to go into your machine. Open your Hyperterminal session. Click on the "Edit" tab, then select the "Paste-to-host" option. The alternative to this is Ctrl+V key combination.
Cheers,
Josef.
PS - please resolve/rate the post...
dstochmal
Thx, I will give it a try on Wednesday.
