Catalyst 2940- Switch drops connection when anothr is added.
FWWITINET
Having an issue with two Cat 2940, they have fiber 100Base-TX. Added a new Cat switch (the second on the VLAN), the existing Cat switch drops the fiber connection. Any thoughts???
The log gives you the answer: "NATIVE_VLAN_MISMATCH"
type "show vlan brief" from exec mode
make sure vlans exist on both switches, if not add them
check that the link between the two devices is trunking on the same native vlan
example:
switchA#show run interface fastethernet0/9
switchport mode trunk
switchport trunk native vlan 27
spanning-tree portfast trunk
SwitchB#show run interface fastethernet0/9
Also, if running VTP make sure domain and password are the same and one is server and the other is client. You can also set them to transparent and update vlans manually.
6 Replies 6
John Blakley
Sounds like a physical problem. Check cabling, sfp, etc....
HTH, John *** Please rate all useful posts ***
Mandlenkosi,
     Sh logs listed below as requested.
sh log
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
    Console logging: level debugging, 7 messages logged
    Monitor logging: level debugging, 0 messages logged
    Buffer logging: level debugging, 7 messages logged
    Exception Logging: size (4096 bytes)
    File logging: disabled
    Trap logging: level informational, 11 message lines logged
--More--
Log Buffer (4096 bytes):
00:00:11: %PLATFORM_CATALYST2940-3-C2940_UPLINK_SELECT: Fa0/9 is selected as uplink port
00:00:14: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
000003: *Mar  1 00:00:16: %SYS-5-CONFIG_I: Configured from memory by console
000004: *Mar  1 00:00:16: %SYS-5-RESTART: System restarted --
IOS (tm) C2940 Software (C2940-I6Q4L2-M), Version 12.1(22)EA12, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 07-Jul-08 23:44 by amvarma
000005: *Mar  1 00:00:16: %SNMP-5-COLDSTART: SNMP agent on host HC_NH_Construction_2940 is undergoing a cold start
000006: *Mar  1 00:00:16: %SNMP-5-COLDSTART: SNMP agent on host HC_NH_Construction_2940 is undergoing a cold start
000007: *Mar  1 00:00:17: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
HC_NH_Construction_2940#
sh log
    Console logging: level debugging, 2005 messages logged
    Buffer logging: level debugging, 2005 messages logged
    Trap logging: level informational, 2009 message lines logged
--More--
E_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001980: *Oct 27 04:57:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001981: *Oct 27 04:58:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001982: *Oct 27 04:59:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001983: *Oct 27 05:00:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001984: *Oct 27 05:01:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001985: *Oct 27 05:02:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001986: *Oct 27 05:03:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
--More--                           001987: *Oct 27 05:04:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001988: *Oct 27 05:05:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001989: *Oct 27 05:06:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001990: *Oct 27 05:07:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001991: *Oct 27 05:08:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001992: *Oct 27 05:09:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001993: *Oct 27 05:10:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001994: *Oct 27 05:11:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
--More--                           001995: *Oct 27 05:12:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001996: *Oct 27 05:13:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001997: *Oct 27 05:14:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001998: *Oct 27 05:15:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
001999: *Oct 27 05:16:27: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/9 (1), with HC_NH_Construction_Cisco2940 FastEthernet0/9 (27).
002000: *Oct 28 15:27:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to down
002001: *Oct 28 15:27:19: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to down
002002: *Oct 28 15:27:51: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to up
002003: *Oct 28 15:27:52: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to up
--More--                           002004: *Oct 29 17:44:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to down
002005: *Oct 29 17:44:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to up
NH_Grd_HS_2940_01# sh log
--More--
NH_Grd_HS_2940_01#
Please post the "sh log"
Mandlenkosi,
     i posted the sh logs in the discussion.
example:
Jszapipes,
    thanks, this solved the issue.
i did not need the "switchport trunk native vlan". But everything else was right on point.
