Catalyst 2950 Password Reset
DPWtech
Our customer has several Catalyst 2950 switches we are reusing for a new project.  We are installing a UPS to feed the Catalyst 2950 switches.  Is a UPS that provides simulated sine wave output acceptable?
'Uses pulse wave modulation to generate a stepped, approximated sine wave to supply cost-effective battery backup power for equipment that does not require sine wave output.'
to be honest, and I have never given much thought to the actual difference between simulated and pure sine wave UPS units, I always recommend APC. They do use pure sine wave, and are sure to work with Cisco devices.
