Catalyst 2950 unable to delete config from Flash - permission denied
Jim Layland
Hi all,
I am currently undergoing an online traing course for CCNA and have just completed a section explaining how to set the boot system option. This triggered a memory of me having an old 2950 switch from a company I used to work which I acquired after they had a switch refresh.
I have located the switch and searched how I can recover it as it is currently protected with a password I do not know. I have booted the switch and held the "mode" button to get it to the "switch:" prompt and followed the instructions found here:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html?referring_site=RE&pos=1&page=http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-121-mainline/6130-index.html
dir flash:  -  produced a list of files in Flash memory and while I couldn't see what looked to be an active config file, there was a file named "config.test.renamed", however, on attempting to delete it I received  a "permission denied" error. This also happen with the files "private-config.text.renamed" and "vlan.dat".
I have found articles on others aspects relating to rommon but nothing identifying with type of error.
Can anyone help please?
Jim
marce1000
        -   Try delete flash:config.test.renamed
 M.
marce1000
 M.
Thanks M.
That's worked a treat   8-)
Aijaz Rehman
Always use flash:   to view or rename or delete a file.
here is the complete process how you reset switch to factory default but make sure you will loose everything.
Step 1.
Connect up your console cable and power on the switch, whilst holding down the “mode” button:
Step 2.
Initialize the flash file system with the command: flash_init
Step 3.
Delete the config.text file from the flash directory:
switch: del flash:config.text
Are you sure you want to delete "flash:config.text" (y/n)?y
File "flash:config.text" deleted
Step 4.
Delete the vlan.dat file from the flash directory:
switch: del flash:vlan.dat
Are you sure you want to delete "vlan.dat" (y/n)?y
File "flash:vlan.dat" deleted
Step 5.
Reboot the switch and you’re done:
switch: boot
