Catalyst 2960-L (WS-C2960L-24TS-LL) Web UI unavailable after upgrade
robcowart
I have a brand new Catalyst 2960-L (WS-C2960L-24TS-LL). After upgrading to the latest IOS and Web UI tar file (c2960l-universalk9-tar.152-7.E3.tar) the Web UI is no longer functioning. It can be reached and I get a basic HTTP login popup, but the page itself never renders. It remains a blank white window. The CLI is still available and works fine.
The upgrade was first completed via the UI, with a subsequent attempt using...
archive download-sw /overwrite /reload tftp://SERVER/c2960l-universalk9-tar.152-7.E3.tar
Neither methods results in a working Web UI.
Does anyone have any insights on how to get the Web UI working again?
Leo Laohoo
This is not the first time we have seen this behaviour in the forum.
The issue is the browser, particularly, the "age".
Try looking for an old browser and see if works.
Reza Sharifi
From the cli, Can you post the output of "sh run"
robcowart
@Reza Sharifi
! Last configuration change at 20:17:24 UTC Thu Feb 4 2021 by abcd
! NVRAM config last updated at 20:18:14 UTC Thu Feb 4 2021 by abcd
version 15.2
no service pad
hostname sw2
boot-start-marker
boot-end-marker
enable secret 5 $1$12345678$12345678.
enable password 12345678
username abcd privilege 15 secret 9 $9$12345678.$12345678.12345678
no aaa new-model
system mtu routing 1500
ip dhcp snooping vlan 3,7-9
sflow agent ip 192.168.2.2
sflow collector id 1 ip 192.168.3.101 port 6343 datagram-size 1280
crypto pki trustpoint TP-self-signed-12345678
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-12345678
 revocation-check none
 rsakeypair TP-self-signed-12345678
crypto pki certificate chain TP-self-signed-12345678
 certificate self-signed 01
  12345678 30820190 12345678 02020101 12345678 2A864886 12345678 05050030
  2F312D30 12345678 04031324 12345678 53656C66 12345678 6E65642D 12345678
  12345678 6174652D 12345678 34303332 12345678 32313032 12345678 30333439
  5A170D33 12345678 31303030 12345678 302F312D 12345678 55040313 12345678
  12345678 662D5369 12345678 2D436572 12345678 63617465 12345678 38343033
  3230819F 12345678 2A864886 12345678 01050003 12345678 81890281 12345678
  12345678 D1AE4F36 12345678 CDAA7BB7 12345678 EAE33D9B 12345678 750E8D3A
  49E3C854 12345678 D02C6F36 12345678 078E3571 12345678 B69A0430 12345678
  12345678 B2A7E2B5 12345678 F6869178 12345678 431B1433 12345678 0857719F
  0742A5F7 12345678 60F98BCF 12345678 701CEBBF 12345678 094C480B 12345678
  12345678 53305130 12345678 1D130101 12345678 030101FF 12345678 551D2304
  18301680 12345678 C32E9543 12345678 5C80DDAC 12345678 7F301D06 12345678
  12345678 3923E0C3 12345678 9CE6655C 12345678 224DFD7F 12345678 2A864886
  F70D0101 12345678 8181008C 12345678 793DB4AE 12345678 EA33EE13 12345678
  12345678 F457CF42 12345678 A4ABCE2B 12345678 2DCC404D 12345678 5090716E
  FAD3A173 12345678 52F5571D 12345678 B5ECC4D7 12345678 4294AC1F 12345678
  12345678 F840B7C4 12345678 4302DD4D 12345678 717EA402 12345678 1934085F
  59524ABA 12345678 3B5D66
  	quit
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
 switchport access vlan 9
 switchport mode access
 sflow flow-sampling input id 1 rate 1024 hdr-size 128
 sflow counter-sampling id 1 interval 30
 spanning-tree portfast edge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 switchport access vlan 7
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
 switchport trunk allowed vlan 1,7-9
 switchport mode trunk
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
 ip address 192.168.2.2 255.255.255.0
ip default-gateway 192.168.2.1
ip http server
ip http banner
ip http secure-server
logging host 192.168.7.10
snmp-server community abcdefgh RO
snmp-server location i,ROBERT
snmp-server contact lab@irobert.info
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps pki
snmp-server enable traps energywise
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps power-ethernet police
snmp-server enable traps cpu threshold
snmp-server enable traps rep
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 192.168.7.10 abcdefgh
snmp mib flash cache
line con 0
line vty 0 4
 password 12345678
 login local
 transport input ssh
line vty 5 15
 password 12345678
 login local
 transport input ssh
monitor session 1 source interface Gi0/24
monitor session 1 destination interface Gi0/23
ntp server 192.168.25.1 source Vlan1
end
