catalyst 2960 management through vlan
Balma1969
I need to put the management interface into a vlan, how can I do it?
mb
Reza Sharifi
If you are trying to use the out of band management interface, it can't be added to a vlan. It is just host port with on IP. If you are not using the OOB interface than it can be added to any vlan.
Thanks NTH.
I'm using an OOB interface so I guess to add it to a vlan I just need to set The Ethernet management port (FastEthernet0) in access mode into that valn.
Is it correct?
I'm connected in telnet to the management IP address. If I do
show running-config interface fastEthernet0
I obtain:
interface fastEthernet0 no ip address
So id the fasEthernet0 my management interface? why it says no ip address?
thanks
mb
