Catalyst 2960-S series boot probleme
faheemahmed100
I have installed fresh IOS everything was going fine I have releoaded the switch all.ok after power cable unplugged n plug again switch struck in boot
11 Replies 11
marce1000
      - Please post a screenshot , including start from the boot until where it get's stuck,
 M.
 Using driver version 1 for media type 1
Base ethernet Mac Address:d4;a0:2a:5e:75:80
Xmodem file system is available.
The password-recovery mechanism  is enabled
  - Check if this topic could be applicable : https://community.cisco.com/t5/other-network-architecture-subjects/c2960-boot-problem/m-p/3746532#M197952
 M.
Can't excite any command doesn't shows
Switch:  where I will execute delete flash: (file name )  or mkdir command
  - In general I can only say ; if you can for instance break into ROMMON while holding the Mode button during boot ; then try the upgrade again ,  make sure to use a correct image and always read the Release Notes of the version you want to install.
Or install again from switch: prompt , if possible - but take note of the above items!
 M.
Can't access the switch: prompt holding the mode button during boot or even with break sequence
 - If the correct upgrade instructions were not followed , including dependencies on previous versions and micro code upgrades , then the device is lost. Try factory reset as last hope,
 M.
Already done all in vain, equally it was working fine after IOS installation, when I powered it off and power on again it was ynabake to boot from flash just showed the error dash wasn't found the boot image ,every time I have to excuse the boot system flash ; flash ******   command to boot but now it is struk in boot process
                                            >.... ,every time I have to excuse the boot system flash
  - If you are in that situation then next time type the command    dir
 M.
Leo Laohoo
HOW, exactly, was the "fresh IOS" was installed?  By xmodem?
C2960s-universalk9-mz.150-2a.se9.bin
