Catalyst 2960 - SFP issue (WS-C2960-24TC-L with GLC-FE-100FX)
thiborba
Hi Team,
I am trying to connect between 2 switches on Fiber.
Switch 1 - WS-C2960-24TC-L
Switch 2 - WS-C2955C-12
On 2955 side I have the fiber with MT-RJ Connector and LC connector on 2960 side.
For 2960 side I have two models of SFP (GLC-FE-100FX and GLC-SX-MM), I intend to use the GLC-FE-100FX, but even before connecting the fiber, I'm just installing the SFP, and the port is err disabling.
Can use one of these SFPs to connect these switches?
First, I just want to make SFP works on 2960 side...after connect the Fiber already connected on 2955 side.
on 2955 side fiber port config are:
interface FastEthernet0/13
description 100FX
switchport mode access
service-policy input gigcst
storm-control broadcast level 1.00 0.90
storm-control action trap
on 2960 side I put these configurations:
interface GigabitEthernet0/1
description 100FX
Need your input please.
regards
Thiago
6 Replies 6
balaji.bandi
Looks like a compatible issue with 2955 check the matrix EXCEL attached both.
I believe 2960 should work - can you post the complete log of the message and show interface gig0/1 (output)
BB
Leo Laohoo
When the port goes into error-disable, post the complete output to the command "sh interface status err".
SWITCH_Y3_A#sh interface status err
Port Name Status Reason
Gi0/1 100FX err-disabled gbic-invalid
According to compatibility matrix, everything os ok
I have two GLC-SX-MM and two GLC-FE-100FX
I need to communicate with a MT-RJ 100FX port of a cisco 2955 , thought that GLC-FE-100FX could fit. Could I set speed of GLC-SX-MM to 100 FX?
Not possible.  GLC-SX-MM(D) will only operate in 1 Gbps, full duplex (and nothing else).  GLC-FE-100FX can only operate in 100 Mbps, full duplex and nothing else.
I'll use the GLC-FE-100FX, according to compatibility matrix, everything os ok
I made a test using two WS-C2960-24TC-L, each one with a GLC-FE-100FX on SFP port gigabitethernet0/1
Both were disabling the port until I ran two commands:
no errdisable detect cause gbic-invalid
service unsupported-transceiver
Ports maintain active buth with no link using optical cable LC MM tested on other port with the GLC-SX-MM and linking OK;
What I still don't understand is the fact that GLC-FE-100FX it is in listed the compatibility matrix and when putting disable (gbic-invalid)
Reza Sharifi
On this switch, can you change the speed and duplex to 100Mb and test again?
BTW, if this is a fiber port, the speed can't be changed.
description 100FX
