Catalyst 2960-X | not booting | Showing " brom> " prompt
Ajay Koorata
I have a 2960-X switch which was in stack configuration. Users complained about network connectivity and while checking the stack i got below error.
Switch1#sh switch
Switch/Stack Mac Address : 1c1d.8605.1d00
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
 1       Member 1c1d.864a.4180     1      4       Ready
*2       Master 1c1d.8605.1d00     1      4       Ready
 3       Member 1c1d.864a.4880     1      4       Ready
 4       Member 1c1d.8674.7a00     1      4       Ready
 5       Member 0000.0000.0000     0      0       Removed
So i consoled to the 5th Switch, however it didn't respond to any inputs.
All the switchport LED's connected to user machines were showing Solid GREEN Light. Now i removed it from stack and Power-Cycled the switch and got below error.
CPU rev: B
Image passed digital signature verification
Board rev: 5
Testing DataBus...
Testing AddressBus...
***ERR -- Expected = 0x55555555, Actual = 0x55555d55 at address 0x00000080
Going to MayDay...
Xmodem file system is available.
flash probe successful
create ifs brom
create ifs bs
brom>
brom>
brom> reset
Are you sure you want to reset the system (y/n)?y
System resetting...
CPU rev: B
Board rev: 5
Testing DataBus...
***ERR -- Address bit 6 stuck at 0.
Expected = 0x55555555, Actual = 0x55555d55 at address 0x00000000
Going to MayDay...
create ifs brom
create ifs bs
brom>
Executed reset command, which didn't help in resolving the issueGoogling for Cisco documentation didn't help much either apart from finding a thread ( http://goo.gl/BHDXOg )which suggested that switch has gone bad and has to replaced.
Any pointers / suggestions  / explanations would be of great help.
Ajay Kumar
Hello Ajay,
This is hardware failure. Please replace it.
Another useful post i found
https://supportforums.cisco.com/discussion/12251826/brom-boot-2960xr-switch
Hope this helps
******Please rate useful posts******
Madhu
Hello Ajay,
Hope this helps
Madhu
Hi Madhu,
Thanks for the input. What i observed is that there no Cisco documentation on this issue apart from few discussions in support forum.
