Catalyst 2960-X Series Switch
Arpita More
I have factory reset Catalyst 2960-X Series, I have deleted the IOS before that and reconfigured it again. Now after rebooting i get the below result. Also the switch became Stack 1 automatically, while it is not.
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 00:b0:e1:5d:c1:00
The password-recovery mechanism is enabled.
APM USBUSB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 10 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 690688
mifs[5]: Bytes available : 1115648
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 2 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1146880
mifs[6]: Bytes available : 2723840
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 1 seconds.
mifs[9]: 654 files, 22 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 54248448
mifs[9]: Bytes available : 67937280
mifs[9]: mifs fsck took 56 seconds.
...done Initializing Flash.
Loading "flash:c2960x-universalk9-mz.152-7.E5"...
Error loading "flash:c2960x-universalk9-mz.152-7.E5"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960x-universalk9-mz.152-7.E5.bin"...Verifying image flash:/c2960x-universalk9-mz.152-7.E5.bin.........................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:/c2960x-universalk9-mz.152-7.E5.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(7)E5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Mon 13-Sep-21 09:41 by mcpre
Initializing flashfs...
mifs[7]: 10 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 690688
mifs[7]: Bytes available : 1115648
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1146880
mifs[8]: Bytes available : 2723840
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 654 files, 22 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 54248448
mifs[11]: Bytes available : 67937280
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
extracting front_end/front_end_ucode_info (43 bytes)
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : MAC Loopback Passed
POST: EMAC Loopback Tests : PHY Loopback Passed
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-24TS-L (APM86XXX) processor (revision K0) with 524288K bytes of memory.
Processor board ID FCW2031A59P
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:B0:E1:5D:C1:00
Motherboard assembly number : 73-15973-02
Power supply part number : 341-0529-02
Motherboard serial number : FOC203124JZ
Power supply serial number : LIT20250EWT
Model revision number : K0
Motherboard revision number : C0
Model number : WS-C2960X-24TS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC20293YJ3
System serial number : FCW2031A59P
Top Assembly Part Number : 800-41470-01
Top Assembly Revision Number : F0
Version ID : V03
CLEI Code Number : CMMMU00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x12
Switch Ports Model SW Version SW Image
* 1 30 WS-C2960X-24TS-L 15.2(7)E5 C2960X-UNIVERSALK9-M
Press RETURN to get started!
*Mar 1 00:00:41.988: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.150: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Apr 27 03:22:26.155: in Switch 0. Cannot read pid from Flexstack module
Apr 27 03:23:08.224: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
Apr 27 03:23:09.618: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Apr 27 03:23:09.618: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Apr 27 03:23:14.557: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Apr 27 03:23:16.179: %PNP-6-PNP_DISCOVERY_STARTED: PnP Discovery started
Apr 27 03:23:37.601: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
Apr 27 03:23:37.601: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
Apr 27 03:23:37.601: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
Apr 27 03:23:38.094: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
Apr 27 03:23:38.210: %SYS-5-RESTART: System restarted --
Apr 27 03:23:38.290: %PNP-6-PNP_BEST_UDI_UPDATE: Best UDI [PID:WS-C2960X-24TS-L,VID:V03,SN:FCW2031A59P] identified via (master-registry)
Apr 27 03:23:38.290: %PNP-6-PNP_CDP_UPDATE: Device UDI [PID:WS-C2960X-24TS-L,VID:V03,SN:FCW2031A59P] identified for CDP
Apr 27 03:23:38.849: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=25: Transceiver has been inserted
Apr 27 03:23:39.901: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Apr 27 03:23:39.940: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11, changed state to up
Apr 27 03:23:40.202: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
Apr 27 03:23:40.943: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11, changed state to up
Apr 27 03:23:41.205: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Apr 27 03:23:42.306: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (1/10) on (GigabitEthernet1/0/11) by (pid=434, pname=PnP Agent Discovery, time=03:23:42 UTC Wed Apr 27 2022)
Apr 27 03:23:44.309: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (2/10) on (GigabitEthernet1/0/11) by (pid=434, pname=PnP Agent Discovery, time=03:23:44 UTC Wed Apr 27 2022)
Apr 27 03:23:58.377: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Apr 27 03:24:04.330: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (3/10) on (GigabitEthernet1/0/11) by (pid=434, pname=PnP Agent Discovery, time=03:24:04 UTC Wed Apr 27 2022)
Apr 27 03:24:06.336: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (4/10) on (GigabitEthernet1/0/11) by (pid=434, pname=PnP Agent Discovery, time=03:24:06 UTC Wed Apr 27 2022)
Apr 27 03:24:09.831: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Apr 27 03:24:26.357: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (5/10) on (Vlan1) by (pid=434, pname=PnP Agent Discovery, time=03:24:26 UTC Wed Apr 27 2022)
Apr 27 03:24:26.357: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (6/10) on (GigabitEthernet1/0/11) by (pid=434, pname=PnP Agent Discovery, time=03:24:26 UTC Wed Apr 27 2022)
Apr 27 03:24:28.363: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (7/10) on (Vlan1) by (pid=434, pname=PnP Agent Discovery, time=03:24:28 UTC Wed Apr 27 2022)
Apr 27 03:24:28.363: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (8/10) on (GigabitEthernet1/0/11) by (pid=434, pname=PnP Agent Discovery, time=03:24:28 UTC Wed Apr 27 2022)
Apr 27 03:24:48.387: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (9/10) on (Vlan1) by (pid=434, pname=PnP Agent Discovery, time=03:24:48 UTC Wed Apr 27 2022)
Apr 27 03:24:48.387: %PNP-3-PNP_DOMAIN_NAME_NOT_FOUND: Domain name not found (10/10) on (GigabitEthernet1/0/11) by (pid=434, pname=PnP Agent Discovery, time=03:24:48 UTC Wed Apr 27 2022)
--- System Configuration Dialog ---
Enable secret warning
In order to access the device manager, an enable secret is required
If you enter the initial configuration dialog, you will be prompted for the enable secret
If you choose not to enter the intial configuration dialog, or if you exit setup without setting the enable secret,
please set an enable secret using the following CLI in configuration mode-
enable secret 0 <cleartext password>
Would you like to enter the initial configuration dialog? [yes/no]:
% Please answer 'yes' or 'no'.
Would you like to enter the initial configuration dialog? [yes/no]: no
Switch>
Switch>
Switch>en
Switch#
Switch#
Switch#
Switch#
Apr 27 03:35:33.234: %PNP-6-PNP_SAVING_TECH_SUMMARY: Saving PnP tech summary (/pnp-tech/pnp-tech-discovery-summary)... Please wait. Do not interrupt.
Apr 27 03:35:35.792: %PNP-6-PNP_SUDI_UPDATE: Device SUDI [PID:WS-C2960X-24TS-L,SN:FCW2031A59P] identified
Apr 27 03:36:27.375: %PNP-6-PNP_TECH_SUMMARY_SAVED_WITH_ALARM: PnP tech summary (/pnp-tech/pnp-tech-discovery-summary) saved with alarm (1/3) (elapsed time: 54 seconds).
Apr 27 03:36:27.375: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard)
Switch con0 is now available
Press RETURN to get started.
USB EHCI 1.00
USB Console INIT
executing...
cisco Systems, Inc.
Election Complete
export@cisco.com.
Version ID : V03
Switch>
Switch>
Switch>en
Switch#
Switch#
Switch#
Switch#
USB EHCI 1.00
USB Console INIT
executing...
cisco Systems, Inc.
Election Complete
export@cisco.com.
Version ID : V03
Switch>
Switch>
Switch>en
Switch#
Switch#
Switch#
Switch#
11 Replies 11
If you have erased the config and started over i believe the default is 1 for switch stack. If it is part of a stack and it’s not supposed to be 1 then it probably hasn’t synced with the other stack members/master. If that’s the case make sure the IOS is the same version.
-David
Leo Laohoo
Is there a Flexstack module at the back?
If it does, power down the switch, remove the stacking module and power it back up.
No Flexstack module is connected at the back. Only power adapter is
connected.
Post the first 10 lines of the "sh run".
The PnP may be causing the switch to reboot (per design).
I have rebooted the switch, the issue is it became stack switch as I have already posted the configuration, Also the old IOS is still reflecting.
Switch>en
Switch#sh run
Building configuration...
Current configuration : 1572 bytes
! Last configuration change at 03:36:27 UTC Wed Apr 27 2022
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960x-24ts-l
Downgrade the firmware to E4.
c2960x-universalk9-mz.152-7.E5 firmware is recommended on cisco.com
Arpita More
No flexstack module is at the back, only power adapter cable is connected, this switch was never used as a stack switch.
 When adding switches in a stack, you need to check the current switch priority. In your case, the switch became the master, probably because its priority is higher then the others:
After that, the switch is trying to re-configure using PnP process.
What you can do is, when it ask for setup:
Answer Y and add basic config.
Or you can answer no but then quickly disable PnP. The command to disable vary but you can try  'pnp disable',  'no pnp enable'
or enter 'pnp' and ? to see the options.
I don't want to add switch in stack.
