Catalyst 2960G Switch Configuration
lcbalogh1
Is there a way to configure a Catalyst 2960G Switch to act like / be an unmanaged (no router capability) switch?  If so, please provide simple, and detailed instructions.
Martin Moran
Level 3
Level 3
Hi @lcbalogh1,
I think that those switches are not routing-capable but one thing ... What you want to do is to have the whole switch in a unique broadcast domain (all ports in the same VLAN), right? If so, follow these steps:
  • Disable the routing capabilities with the "no ip routing" global configuration command
  • If the first command is not accepted, type the "no dsm prefer lanbase-routing"
These two steps above disable the routing capabilities.
Ok, to make all ports members of the same VLAN you have some options:
  • You can let all ports in the default VLAN (VLAN 1)
  • Or, You can configure all ports in another different VLAN
    • switchport mode access
    • switchport access vlan <vlan-id>
Hope this is useful for you.
Rgrds,
Martin, IT Specialist
Martin Moran
Level 3
Level 3
Hi @lcbalogh1,
Rgrds,
lcbalogh1
You're a peach!  Thank you!
