Catalyst 2960L WebUI working but not loading page
Lukaviye
Hi all,
I have a strange behavior from WebUI. After updating a 2960L to 15.2.7E3 I have been unable to access the content of the switch web pges.
The HTML folder is there, after learning that the .tar file is the right upgrade (initially updated to the wrong .bin file losing HTML).
When connecting via HTTP (Edge Chromium and Chrome) the login popup shows but once past that, the page has trouble loading: it flashes as if to start showing something that gets immediately suppressed.
I believe this is a Windows or browser problem. This would be with latest versions of both Chrome and Edge (Chromium) on up-to-date Windows 10, on a wired network. I have the switch IP in Trusted Sites, allowed everything in Site Settings for the particular site address, firewall is down.
A Google search on the problem did not yield useful results. I doubt this is a new bug or issue. Thank you in advance for your help.
14 Replies 14
Reza Sharifi
I think that is a browser issue. Try using MS edge browser that comes with windows 10 and test.
Reza, Thank you for responding. I was on Chromium-based Edge already.
In the meantime, however, I have tried IE on Windows10 and that browser loads the pages, but not all frames. As seen in the image below, for example, Switch View is not available. Should anyone have suggestions, I would be happy to test.
just a thought: try and clear the browser cache, that sometimes helps...
Hi Georg,
Yes, sometimes it does. Tried that, no change. Also tried on a different Windows 10 box and had the exact same issues.
Leo Laohoo
Post the complete output to the following commands:
sh version
dir
Hi Leo, here it goes:
SWITCH#sh version
Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(7)E3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sun 06-Sep-20 11:19 by prod_rel_team
ROM: Bootstrap program is C2960L boot loader
BOOTLDR: C2960L Boot Loader (C2960L-HBOOT-M) Version 15.2(5r)E3, RELEASE SOFTWARE (fc2)
SWITCH#dir
Directory of flash:/
516 -rwx 3096 Dec 9 2020 05:31:28 +00:00 multiple-fs
515 -rwx 1922 Dec 9 2020 05:31:27 +00:00 private-config.text
514 -rwx 2134 Dec 9 2020 05:31:27 +00:00 config.text
257 -rwx 208 Nov 26 2020 05:46:50 +00:00 express_setup.debug
259 drwx 2048 Dec 9 2020 00:15:24 +00:00 uploadFile
258 -rwx 556 Nov 29 2020 00:14:43 +00:00 vlan.dat
792 drwx 2048 Dec 9 2020 04:36:01 +00:00 c2960l-universalk9-mz.152-7.E3
274 drwx 2048 Dec 9 2020 04:36:01 +00:00 dc_profile_dir
2 drwx 2048 Mar 1 1993 00:00:02 +00:00 lost+found
244711424 bytes total (192624640 bytes free)
Post the complete output to the following command:
dir flash:c2960l-universalk9-mz.152-7.E3/html
Is Java up to date on your PC?
Cisco was never good at software development.
Ain't that the truth.
Leo,
It is only going to get worse especially now that AWS is taking all their switching and routing business and converting it to software as a service. AWS is making everything so easy. It's all point and clicks nowadays.
It APPEARS that a complete new install of Java AND enabling Flash manually has fixed the issue. However, not without some restarts. Chrome worked off the bat while Edge (Chromium) took a restart. I will keep an eye on the issue. The OS+WebUI update added a ton of functionalities to the Web UI making it actually useful and worth the work to update (after killing it yesterday - different thread).
I have to be honest, I am new to Cisco managed switches, and I am not impressed. I worked at Intel for a number of years starting out of college as a sw tester and the documentation inconsistencies, the compatibility failures, the scant information provided, the broken links and awful navigation of the main web site that I see here would never have passed. I will tell you I also tried to configure a Catalyst 1000 at this same time and just send it back when I could not even get to the configurator: the guides have it wrong. The only thing here is the community that is an unbelievable help.
I will shortly post other info as requested by Leo just to get to he bottom of it.
Oh good.  You haven't seen the information found in the majority of Bug IDs.
Leo,
Want a cheap laugh? First thing I saw when finally managed to open the page on a browser was a bug that appears to be undocumented/unreported. (Not that I would care to.)
The POE power consumption pie chart in Web UI does not report power in use. As you can see from the image attached, pie chart reports zero power consumption, while clearly two ports are supplying power to devices, and a mouse hover alt-tag correctly displays remaining power budget (154.6) as I am using 40.4W on 195W total power budget.
Here, Leo the dir output:
Directory of flash:c2960l-universalk9-mz.152-7.E3/html/
795 drwx 2048 Dec 9 2020 04:32:07 +00:00 day0
854 -rwx 17876 Dec 9 2020 04:32:08 +00:00 express-setup.htm
855 drwx 2048 Dec 9 2020 04:32:14 +00:00 utils
912 drwx 2048 Dec 9 2020 04:32:14 +00:00 macros
914 -rwx 17876 Dec 9 2020 04:32:14 +00:00 express-setup.html
915 drwx 2048 Dec 9 2020 04:32:35 +00:00 features
1059 drwx 2048 Dec 9 2020 04:32:36 +00:00 tests
1063 -rwx 5845 Dec 9 2020 04:32:36 +00:00 logout.html
1064 -rwx 8229 Dec 9 2020 04:32:36 +00:00 index.html
1065 drwx 2048 Dec 9 2020 04:32:36 +00:00 onlinehelp
1066 -rwx 13832 Dec 9 2020 04:32:36 +00:00 app.js
1067 drwx 2048 Dec 9 2020 04:33:16 +00:00 lib
1134 -rwx 566 Dec 9 2020 04:33:18 +00:00 config.js
1135 drwx 2048 Dec 9 2020 04:33:19 +00:00 js
1138 drwx 2048 Dec 9 2020 04:33:51 +00:00 resources
1208 -rwx 143 Dec 9 2020 04:33:51 +00:00 version.js
1209 drwx 2048 Dec 9 2020 04:33:58 +00:00 odm
1027 drwx 2048 Dec 9 2020 04:34:04 +00:00 nls
