Catalyst 2960S Port-Based Address Allocation
Phuong Trinh
I just bought a Catalyst 2960S to test out the feature "Port-Based Address Allocation" which is required for our factory. I followed the instruction from Cisco IOS and did all the steps but I could not get it to work, my network client did not received the expected IP address that I configured. Is there any one got this thing working? any help would be awesome.
Phuong
config t
int range g1/0/1 -3
switchport mode access
switchport access vlan 2
exit
int vlan 2
ip address 192.168.1.x
Regards.
Alain
9 Replies 9
singhaam007
Level 3
Level 3
hello,
could you please check this link and see if you following the correct procedure
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swdhcp82.html#wp1320926
go to
Port-Based Address Allocation Configuration Guidelines
please let me know if this helps.
thanks
Yes, I did follow the same guide. I just tried to set up for 3 ports and when I plugged the client into the port, DHCP failed . Below is my running-config. Wonder I missed anything or did something wrong.
Switch#show running-config
Building configuration...
Current configuration : 1871 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960s-24ts-l
ip dhcp use subscriber-id client-id
ip dhcp subscriber-id interface-name
ip dhcp pool vlan2
   network 192.168.1.0 255.255.255.0
   address 192.168.1.1 client-id "Gi1/0/1" ascii
   address 192.168.1.2 client-id "Gi1/0/2" ascii
   address 192.168.1.3 client-id "Gi1/0/3" ascii
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
ip dhcp server use subscriber-id client-id
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
--More--
I noticed that you named your DHCP pool Vlan2, are you using Vlan2 in the config? My guess would be that you don't have the ports setup for Vlan2, hence the reason they are not getting DCHP.
Try putting the 3 ports in vlan 2 and see what happens.
Switchport access vlan 2
since hte bottom part of the config is missing I thinking that you have an interface vlan2 with an ip address.
Jamescox3, thanks so much for fast response. Can you tell me how to do that, I' m so new to the CLI.
Could you post the full config from the switch
Sure,
Current configuration : 1892 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool vlan2
ip dhcp pool vlan1
no ip address
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
ip http server
ip http secure-server
line con 0
line vty 5 15
end
Switch#
config t
int range g1/0/1 -3
exit
int vlan 2
Regards.
Alain
Working now. Thanks for all your help
@PhuongTrinh Hi, I am trying to achieve the same. but I am having trouble where the last byte of the interface name is lost (32). Please advise.
VRF: IP address Client-ID/ Lease expiration Type Hardware address/ User name 192.168.100.1 0047.6931.2f30.2f Jan 09 2016 04:53 AM Automatic 192.168.100.5 0047.6931.2f30.2f32 Infinite Manual'
