Catalyst 2960X - POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 10
Vinnfier93
Hi all,
I have issue on cisco catalyst C2960X-48TS-L. The error messages is below:
POST: PortASIC Port Loopback Tests : Begin
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 9
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 12
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 11
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 16
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 15
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 18
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 17
POST: PortASIC Port Loopback Tests : End, Status Failed
Error: ASIC/PHY POST failed. Cannot continue.
%Software-forced reload
I have tried reload image but nothing was fixed.
Please advice for the best solution.
thanks
Leo Laohoo
Contact Cisco TAC and organize for am RMA.
The switch is dead.
If you have reboot the switch several times then it is no longer CSCut90593.
Leo Laohoo
The switch is dead.
Hi Leo,
Yes I think same like you too. because I have tried xmodem and check all in rommon but nothing cant fix it. actually.
Just wanna confirmation with it.
