Catalyst 2980G-A
waseemmirza
Status is Orange Light
sachinraja
Level 9
Level 9
Hello waseem,
Is the switch in the rommon mode ? can you login to the console and let us know the status ?? Attached a URL which gives some basic info on troubleshooting these switches..
http://cisco.com/en/US/products/hw/switches/ps606/products_installation_guide_chapter09186a00801d57fe.html#1015055
is it a working switch or a new one ? If new, u might have to also do a RMA !!!!
Hope this helps..all the best. rate replies if found useful.
Raj
It is a working switch, the only problem was that one of the three cooling fans was not working and I replaced it with the new one, and after that when booting the status is orange, power is green and RPSU green.
