Catalyst 3500 VLAN Config problem
jerrysafetynet
I've got a Cisco Catalyst 3500 switch. I have an Access Point in port 13 which in on VLAN 20. That AP pulls its IP from our Gateway, and that part is working fine. The AP itself also has a VLAN setup on it because I want the users to pull from a differnt scope of IPs. I cannot get the users to get an IP address from the AP. Port 13 is setup for VLAN Access, how can I set it up for trunking the VLAN info from the AP. I was able to get this working with ZyXEL switches, just not with Cisco. Any help would be great
8 Replies 8
glen.grant
you will probably have to post the configs of the switch and the AP . Is the AP a cisco also ?
Thanks. No, the AP is a Colubris Access Point
I enabled trunking on port 13, but that did not work. Gateway is plugged into port 24, Nomadix Gateway
sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SafetyNet
enable secret xxx
ip subnet-zero
interface FastEthernet0/1
--More-- !
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
switchport access vlan 20
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
--More-- interface FastEthernet0/12
interface FastEthernet0/13
switchport priority default 7
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
--More-- !
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 10.15.10.5 255.255.254.0
no ip directed-broadcast
no ip route-cache
ip default-gateway 10.15.10.1
snmp-server engineID local 00000009020000B06490C940
snmp-server community private RW
snmp-server community public RO
snmp-server chassis-id 0x12
--More-- !
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
SafetyNet#
Thats not the correct configuration for a trunk.
switchport trunk native vlan
By default the native vlan on a switch trunk port is 1, can you check what is the native vlan on the AP.
Try configuring a local DHCP on the switch to see if the problem is with the trunk port or somewhere else.
I've set the VLAN on the AP to 50. I'll try adding the switchport trunk native vlan 50 tomorrow. thanks for the help
I do need the VLAN to be access mode as well, as the AP needs to be on VLAN 20 to get the correct DHCP IP address from the gateway.
It won't be in access mode if you trunk it but that doesn't matter because vlan 20 is trunked to the switch along with whatever other vlan you create. The vlan 20 tag gets stripped at the switch which passes it along to the dhcp server.
Thanks for the reply's. I need the AP's in their own VLAN's, which I made VLAN 20. When the AP's boot up, they will be in VLAN 20, and when they come across on VLAN 20, they will pull from the correct DHCP scope, based on that VLAN. Next, I've created an egress VLAN of 50 on the AP's. When the users connect to the AP, they will traverse the switches with VLAN 50, and pull from a differnet DHCP scope based on that VLAN. So I need the port to kind of do both, access and trunk, is this possible?
I tried "tlohumi"'s suggestion. Setting the native VLAN did work for getting the AP to show up on that VLAN, but I need the AP on one VLAN, and the users connecting to the AP on another VLAN that is provided by the AP.
