Which Gigabit Ethernet linecards can I use with 4003 and Sup1
it would be very fine if somebody could tell me which ge linecards I can use in a catalyst 4003 chassis with a ws-x4012 supervisor engine 1.
Is it possible to use the 4448 or 4548 linecards?
Many thanks in advance,
Thorsten Steffen
andrew.burns
Level 7
Level 7
The following link shows the supported modules:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/installation/guide/01intro.html
Although it sounds like you'll be ok to use these modules, this platform is very nearly obsolete and the switch fabric is only 12Gbps.
Andrew.
