06-16-2006 07:33 AM - edited 03-05-2019 11:57 AM
hi,
i tried to setup a catalyst 3500 XL to run with VoIP.
I need on a port to TAG 2 VLAN (link to the backbone), and on the others to tag one VLAN (voice one) and untagged the data vlan.
unfortunately, through the web interfcae and through the IOS command i could not setup this configuration.
have any idea?
BR,
Laurent Viollet
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.1)XP, MAINTENANCE IN
TERIM SOFTWARE
06-16-2006 07:51 AM
The uplink to the other switch where you want all the vlans tagged:
conf t
int fa x/x
switch
switch trunk dot1q native vlan 99 >> vlan 99 is a dummy vlan that is not used for any data or voice, we just use this to make sure all is tag since native vlan in dot1q is not tagged with vlan id.
int fa x/x
switchport
switchport trunk dot1 native vlan 2 >> the data vlan.
Please rate helpful posts.
06-16-2006 10:31 PM
hi bosalaza,
a minor correction to post i think we don't have to use switchport command in 3550 XL though it's all port bydefault L2.
and one more thing that
we could have two case
1- Voice vlan + data vlan
2- any two vlan
3- trunk with native vlan
where do we use vlan 0 in this case
Thanks in advance.
06-16-2006 11:17 PM
vlan 0 does not exist, it cannot be created. I don't understand what you meant by 1, 2, and 3. XL does not support "voice vlan", you have to use trunk:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/2935wc15/ol256211.htm
