Catalyst 3560-CX console works, but no CLI prompt
DmitryBond
Dear colleagues,
Please help with following case.
I have WS-C3560CX-12PC-S switch which doesn't allow configuration over console CLI - no command prompt showing. Same time console hardware is fully working, as I'm able to send commands when in bootloader mode.
After boot process i see message "Press RETURN to get started!" but no reaction to any input. If I connect or disconnect ethernet cables to switch console continue to show log output, so it doesn't hang.
*Mar  1 00:00:18.014: Read env variable - LICENSE_BOOT_LEVEL = ipservices
*Jan  2 00:00:00.517: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3560cx Next reboot level = ipbase and Lice        se = No valid license found
Jan 10 05:01:16.036: %HARDWARE-3-MCU_I2C_READ_ERROR: I2C read failed in MCU and attached devices (e.g. Temperature Sensor) can'        be read.
Jan 10 05:01:17.948: %HARDWARE-3-MCU_I2C_BAD_DEV: I2C bad device address: 0 (alchemy:0)
Jan 10 05:01:36.749: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Jan 10 05:01:41.712: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Jan 10 05:01:44.757: %PNP-6-PNP_DISCOVERY_STARTED: PnP Discovery started
Jan 10 05:02:06.085: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3560CX Software (C3560CX-UNIVERSALK9-M), Version 15.2(7)E3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sun 06-Sep-20 15:15 by prod_rel_team
Jan 10 05:02:06.155: %PNP-6-PNP_BEST_UDI_UPDATE: Best UDI [PID:WS-C3560CX-12PC-S,VID:V03,SN:[cut]] identified via (master        registry)
Jan 10 05:02:06.158: %PNP-6-PNP_CDP_UPDATE: Device UDI [PID:WS-C3560CX-12PC-S,VID:V03,SN:[cut]] identified for CDP
Jan 10 05:02:08.318: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Jan 10 05:02:09.007: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
I've tried to boot to bootloader (MODE button long press) and do xmodem reflashing new FW after full flash format. This operation succeeded (confirming that console is working), but after reboot again no CLI prompt.
Below are my boot env variables. Maybe it could be helpful somehow:
switch: set
BOARD_CONFIG_REV=3
BOOT=flash:/c3560cx-universalk9-mz.152-4.E2/c3560cx-universalk9-mz.152-4.E2.bin
CLEI_CODE_NUMBER=[cut]
ENABLE_BREAK=1
IMAGE_UPGRADE=yes
MAC_ADDR=2C:AB:EB:[cut]
MODEL_NUM=WS-C3560CX-12PC-S
MODEL_REVISION_NUM=H0
MOTHERBOARD_ASSEMBLY_NUM=73-[cut]-04
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FOC[cut]
POWER_SUPPLY_PART_NUM=341-[cut]-02
POWER_SUPPLY_SERIAL_NUM=DC[cut]
SDM_TEMPLATE_ID=0
SWITCH_PRIORITY=1
SYSTEM_DOWNSHIFT_CFG=1
SYSTEM_DOWNSHIFT_COUNTER_CFG=3
SYSTEM_SERIAL_NUM=FOC[cut]
TAN_NUM=68-[cut]-01
TAN_REVISION_NUMBER=A0
VERSION_ID=V03
Leo Laohoo
Switch is dead.
Contact Cisco TAC and organize for an RMA.
